E-Fan Installed, now running hot
#32
Alright, I was thinking that maybe with part of the shroud missing that I was getting some sort of cooling problems. Ordered the Relays and got the fuse holder and fuses. I am going to run to a switch that will control which relay will be getting power to turn on and I was wondering if there was a rubber gromet to run the wires thru the firewall. I haven't checked yet, but figured I'd ask what the best way to accomplish this would be.
#33
Just do it right and spend $40 on a controller and save the engine.
There are a few places right behind and beside the brake booster you can go through
#34
#35
[quote=weedahoe;2243327]Bad idea on the switch because if you ever forget or loan your truck out and it doesnt get turned on.....then you over heat.
I'm getting a Single Pole, Double Throw switch so one of the fans will be active at one time. This prevents the low side temp sensor relay from activating while the High side is running.
#37
Also, can you please post your electrical diagram of how you are going to run this. That way maybe I can understand better.
#38
#39
garider i did mine about 3 weeks ago and i had $80 bucks into it total and all my stuff was brand new so i would do some more searching if you're coming up with $150. Some guys are willing to buy a used fan and in that case i'm sure you could get cost down to $50 total. The benefit is it is one less thing the engine is pulling so i was able to gain just over 1 mpg for $80 and 4 hours of work. The more important part is you get rid of the loud cluth fan so you can hear more important things like the exhaust.
