Bolts required for OEM hitch
Old Jun 21, 2010 | 10:33 PM
AlbertaRAM's Avatar
AlbertaRAM
Default Bolts required for OEM hitch
I have an OEM hitch on it's way to me but it doesn't have any of the bolts on it (and I don't have an OEM hitch already). Does anyone know what size bolts are required (and how many of each) OR a place where I can get a bolt package for an OEM hitch?
Thanks!
Old Jun 21, 2010 | 10:35 PM
ramhunter9's Avatar
ramhunter9
when you get the hitch measure the holes ..go to hardwear store get bolts , washers , and lock washers .
Old Jun 21, 2010 | 10:46 PM
AlbertaRAM's Avatar
AlbertaRAM
Haha ya that's the backup plan... but was hoping I could find out ahead of time so I can have the hardware ready to go.
Thanks!
Old Jun 21, 2010 | 10:47 PM
ramhunter9's Avatar
ramhunter9
i will measure mine in the am for ya pal .
Old Jun 21, 2010 | 10:52 PM
RedTruck-VA's Avatar
RedTruck-VA
I have one all pulled apart. Let me know and I'll take pictures and measurements if you need it.
Old Jun 21, 2010 | 10:55 PM
hemiguy0302's Avatar
hemiguy0302
I was just gonna say park yourself in front of a not and bolt shop.
Old Jun 21, 2010 | 10:57 PM
ramhunter9's Avatar
ramhunter9
not and bolt shop hmmm must be a canada thing lol .
Old Jun 21, 2010 | 10:58 PM
jake7's Avatar
jake7
Find yourself someone with a set up and take theirs...or measure it..
Old Jun 21, 2010 | 10:59 PM
hemiguy0302
Edmonton nut and bolt. A whole shop for nuts and bolts. If you need it they will have it. Definitely the best thing ever.
Old Jun 22, 2010 | 12:00 AM
03MopaRamman's Avatar
03MopaRamman
When I got mine (Putco OEM equivalent) it came with 2 nuts on a fairly long piece of wire that you have to feed inside the tube to have the ability to line them up to start threading in the bolts. Can't remember but it was a PIA, and also can't remember how I torqued them (musta been able to put a stubby in there). I'm gettin old but not crazy. I am speaking BTW of the curved frame piece and also learned that if you buy a used 1500 and want to know if it had a prior hitch, just tap that part of the frame and if it did there will be two nuts floating around in there loose (as I found out).
So that said good luck as you may have to ducktape your nuts to a coathanger to get yourself properly hitched...
