Traction Control problem
Old Jun 28, 2010 | 06:57 PM
  #21
ryangsxr750's Avatar
ryangsxr750
So that being said where is the best place to purchase superchip?
Cheapest?
Old Jun 28, 2010 | 07:15 PM
  #22
chambers's Avatar
chambers
Cheapest would probably be the classifieds for a used one that isn't VIN locked, next would be Moesperformance, airram, or ebay.
Old Feb 1, 2013 | 08:35 PM
  #23
ryangsxr750
Hey Guys....
I am back still with the same problem but with different wheels and tires....
SO this is what I have now same truck (2007 RAM 1500 Hemi 4x4 Laramie) now I have 35" Nitto trail grappler tires on some 18" Fuel Black wheels
Any ideas now why when I go around a corner does my traction control turn on and turn on my ABS???? I am tired of it
Old Feb 1, 2013 | 10:01 PM
  #24
08HEMI1500's Avatar
08HEMI1500
You should have just went to the dealer right away so it was their responsibility and dollar to fix it. Now you'll probably have to pay out of pocket for a diagnosis and repair. Good luck. Idk what cold be causing your issue because I've taken turns at 20 mph and greater and never had a light come on. In fact the only time I've even seen any of the lights you're talking about is when I turn my truck on and I have a 6" lift and 34" tires so I'm similar to you. Maybe you have some bad wires that are getting crunched in the turn that set off the light?
Old Feb 2, 2013 | 01:39 PM
  #25
ryangsxr750
Yes I should have been more adament about the problem from the place I bought it from. And the truck was at a dodge dealer after I bought the truck. They replaced some clockspring sensor in the steering wheel cause thats the code they found in the computer system (the place I bought the truck from payed for that) but it never fixed the problem.
Is there a way to disable the traction control? A fuse to pull? I have not looked yet
Old Feb 2, 2013 | 01:40 PM
  #26
ryangsxr750
Did you have your truck reprogrammed for the new tire size or do you have a programmer to do it yourself?
Old Feb 2, 2013 | 01:41 PM
  #27
08HEMI1500's Avatar
08HEMI1500
I'm sure you can pull a fuse but I wouldn't. That sounds like a terrible idea and a potential lawsuit if you get in an accident and it's discovered that you did that
Old Feb 2, 2013 | 01:45 PM
  #28
ryangsxr750
Here is the truck now BTW
Old Feb 2, 2013 | 01:47 PM
  #29
ryangsxr750
What would not having the fuse in there have to do with a lawsuit? I dont want the traction control anyways. I know how to drive in the snow and ice
