HELP!!, I keep blowing fuse number 51
Old Jun 28, 2010 | 12:48 AM
06 RMK 900's Avatar
06 RMK 900
Default HELP!!, I keep blowing fuse number 51
I need some help please I keep blowing fuse number 51. What could cause this one to keep blowing. The only thing I did to the pickup this weekend was change plugs (wich everything was working good after that) and I mounted my cutout switch. If I disconnect the bat and put in a new fuse as soon as I reconnect the bat the fuse pops. It does it before I turn on the ignition. Things that don't work with this fuse is, radio, key fob, and door lights. Any help would be great, I don't mind working on the motor but the wires scare me.
Old Jun 28, 2010 | 08:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Obviously either a component failed or a wire has shorted out. See if this helps. Start by unplugging things that already do not work such as the radio and see if it goes away. If not then it is in your wiring.
Also see if this schematic helps you out any.
Old Jun 28, 2010 | 10:06 AM
dirtydog's Avatar
dirtydog
Moderate User
Nice post up weedahoe.
You said you mounted your cut-out switch. Did you dod any wiring for it and if so what?
Old Jun 28, 2010 | 10:29 AM
06 RMK 900's Avatar
06 RMK 900
I have had it wired for the last 4 months just had the switch flopping around so I drilled a hole in below the cup holder area and mounted it. I'm going to run to town and get some more fuses and start by disconnecting everything I added on - Amp, cutout, Air pump.
Old Jun 28, 2010 | 10:37 AM
RedTruck-VA's Avatar
RedTruck-VA
With just a quick look at the drawing I would take a very close look at the cutout switch you installed. Disconnect it and backtrack your steps. Good luck..
Old Jun 28, 2010 | 10:50 AM
dirtydog's Avatar
dirtydog
Moderate User
I don't think the cut-out has anything to do with it unless he tapped into fuse 51's power wire and possibly crossed wires or maybe they melted or contacted each other when he mounted the switch otherwise the additional current draw the past 4mo. would have already caused the fuse to pop. Pull the switch out and see if there are any issue's.
Actually Weed, did you forget to attach the 8w-10-14 the previous schematic because I see nothing about the radio/horn/cigar type stuff.
unplugging stuff may help isolate the issue, but you really need to start poking around with a miltimeter to find the problem.
Old Jun 28, 2010 | 10:53 AM
brettj2408's Avatar
brettj2408
the cutout switch you wired is probably shorting the wires on the backside of it. apply some tape inbetween the terminals and see what happens.
Old Jun 28, 2010 | 11:25 AM
06 RMK 900's Avatar
06 RMK 900
Thanks everyone for your inputs I just found the problem. I disconnected all my add ons and it was still blowing. looked under the above the pedals and found that my OBDII plug has come apart and one of the prongs was touching the metal!.
So i'm off to a junk yard to get a new plug so I can hook up my Aeroforce when it gets here in a couple hours.
Unless someone can tell me which prongs go into wich hole on that plastic clip "thing" that seperates the prongs!
Old Jun 28, 2010 | 11:32 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Actually, I didnt forget. When i looked over that one the first time I didnt see fuse 51 on it. But since you mentioned it I went back and looked more carefully and DID see it so i edited my post and added it.
THX for catching that.
Old Jun 28, 2010 | 11:37 AM
brettj2408's Avatar
brettj2408
CAVCIRCUITFUNCTION--
1--EMPTY
2--D25 20WT/VTPCI BUS
3--EMPTY
4--Z11 18BK/LGGROUND
5--Z111 18BK/WTGROUND
6--EMPTY
7--7D21 18WT/BR (GAS)SCI TRANSMIT (PCM)
8--EMPTY
9--D16 18WT/OR (EXCEPT SRT)SCI RECEIVE (TCM)
10--EMPTY
11--EMPTY
12--D20 20WT/LG (DIESEL)SCI RECEIVE (ECM)
12--D20 20WT/LG (GAS)SCI RECEIVE (PCM)
13--EMPTY
14--EMPTY
15--D15 18WT/DG (EXCEPT SRT)SCI TRANSMIT (TCM)
16--A114 18GY/RDFUSED B(+)
