first time spark plug change.
Old Jun 29, 2010 | 05:07 PM
Senomar_DTK's Avatar
Senomar_DTK
Default first time spark plug change.
I went out an bought 8 new plugs and Im gonna change them soon but do I really need a torque wrench to tighten them to the specific rating or will I be fine just using my regular wrench?
Other then that it seems pretty simple to do
Old Jun 29, 2010 | 05:17 PM
Big_Wheel's Avatar
Big_Wheel
yea .. go snug and then 1/8 of a turn. They dont need much i think its like what 14Ft/lbs?
Old Jun 29, 2010 | 05:29 PM
blakeroberts88's Avatar
blakeroberts88
I will pay someone to change the plugs in my truck next time.. 16 plugs sucked...
Old Jun 29, 2010 | 05:31 PM
dirtydog's Avatar
dirtydog
Moderate User
^^ yeah what he said. I generally go snug and then turn the wrench 1hr more. So is snug = 1'o'clock then go to 2'o'clock.
A little tip..When you are doing your plugs, the socket likes to bind itself on the spark plug threads sometimes so once you are torqued down, just put a tiny bit of pressure almost as if your gonna loosen the plug and that frees the socket from the plug.
Make sure you check the gap on all the plugs even if they are "pre-gapped".
Old Jun 29, 2010 | 06:02 PM
MikeHTally's Avatar
MikeHTally
A hour?! That's a long time The torque is 14 ft/lbs, but snug plus a bit is just fine. Remember, the head is aluminum. This came in very handy when I did my C. It and a couple different length extensions and a swivel will make it easier.
http://www.harborfreight.com/extende...ket-91705.html
Old Jun 29, 2010 | 06:20 PM
brettj2408's Avatar
brettj2408
if its the new 4.7 that has 16 plugs they can be difficult. you will need to take off the airbox that hooks to the throttle body.
for a person that has never done a tune up before i would give it a good 3 hours or so.
personally when im at the dealer i can get it done in 45 min to an hour but i am a mechanic that does this 2 - 3 times a week with the exact tools i need
Old Jun 29, 2010 | 07:41 PM
MikeHTally's Avatar
MikeHTally
Didn't the 4.7 not get 16 plugs 'til the '08 MY? Plus, only eight get changed at the lower mileage. The bottom eight are good to 102K.
Old Jun 29, 2010 | 08:01 PM
brettj2408's Avatar
brettj2408
the 07.5 have the new 4.7s that why i asked. you need to change the coil ones every 30k and the plug ones every 100K.
so depending on his motor either 8 or 16
Old Jun 29, 2010 | 08:34 PM
osp1560's Avatar
osp1560
a friend just spent $424.00 to have his 16 plugs changed, oil change and wipers... It was worth the couple hours for the cash saved!
Old Jun 29, 2010 | 10:42 PM
blakeroberts88
After seeing that astronomical number I think I will just suck it up and change them myself.
