My Cold air intake ???
I just did mine too recently. For some reason everytime I start the truck it dings and tells me to change the oil. The oil is full synthetic and only has 2k miles on it. Plus when I pull the stick it looks good and is topped of. Any ideas? Maybe I just need to reset it?
If so, you're probably getting too high of a plutonium level in your flux capacitor and need to switch to irridium.
I've heard this guy in a mansion with some cool iron suits has a new element, too that is supposed to reduce the uranium toxicity levels. If I had to guess, that's what it would be -- if nothing else just make sure rayon field sensor is still working -- sometimes that throws an error code for me.
If all else fails -- just reset the oil change light. It's a long shot, but that might be what is causing all our problems.
alot of times time is money so i mean if its easier for you and you dont mind spending the cash then by all means ...i just find time and save money for better mods...i bought a cai but its a mopar knock off and it was under 70 bucks at the time i had the money and no time...now if i needed to i would pvc it....but i already went there....
No I didn't reset it, I wasn't even aware that I had to reset it. How do I do it, same as getting codes? Just turning the key on and off a few times? Thanks for the heads up!
Are you still using palladium cores?
