New Shock install tomorrow?
Old Jul 8, 2010 | 11:54 PM
mattwv88's Avatar
mattwv88
Default New Shock install tomorrow?
Hey guys,
I got pro comp shocks and I am going to install them tomorrow. Can I do it with out a torque wrench? How tight do I make the top and bottom bolts? I am concerned about doing this my self but I guess I am going to give it a shot. Any and all words of wisdom would be great.
Thanks
Old Jul 9, 2010 | 02:12 AM
brettj2408's Avatar
brettj2408
its a fairly easy job. and no you will not need a torque wrench unless you want to use it for peace of mind.
just make sure and tighten them pretty snug plus some haha.
any questions feel free to ask, we are all here to help.
Old Jul 9, 2010 | 06:17 AM
marky0304's Avatar
marky0304
Drop the spare tire in the rear, it will give you more working room. And use anti-seize.
Old Jul 9, 2010 | 06:18 AM
marky0304's Avatar
marky0304
And remove the plastic shroud behind the driver's side real wheel. 3 8mm bolts hold it in place.
Old Jul 9, 2010 | 06:36 AM
sup_mario's Avatar
sup_mario
Good luck on installing it man. You can do that.
Old Jul 9, 2010 | 07:02 AM
Big_Wheel's Avatar
Big_Wheel
yea you can do it with removing the spare tire or that plastic shroud...mud flap? guessing thats what the other guy is talking about.
should be dont all 4 shocks in 20-30 minutes for a first timer....way way faster if you have air tools .
Old Jul 9, 2010 | 07:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As others have said, its not hard and you do not NEED a TQ wrench.
Old Jul 9, 2010 | 08:49 PM
mattwv88's Avatar
mattwv88
I got them on! Took a while longer than I thought it would. Ended up putting about 4 hours into all 4 of them. Had a really really hard time getting the rear ones off!! It rides 100 times better than it did on the stock ones. It even sets alittle higher now. Was able to crank my t-bar and get it level now. Thanks for all the advice and support!
One problem though. I have the Top gunz leveling key and now since I cranked my t-bar up alittle more one of my t-bar ajustment bolts is sitting side ways. How they normaly go straight up and down it is sitting kind of sideways. Just had to crank it alittle more to get it up. How can I get it to set straight? The other one is pretty much straight but the passenger one is not.
Thanks
Old Jul 10, 2010 | 12:47 PM
mattwv88's Avatar
mattwv88
bump.......
