2003 Ram 1500 4X4 5.7 Liter V8 Electrical problems.
Old 07-20-2010 | 11:55 PM
That1guy's Avatar
That1guy
Originally Posted by luckydt
i recently had a run in with the abs light, brake light, and speedometer not working. the codes were coming up with speed sensore and unable to communicate with abs module. it wound up being a 15A fuse in the main fuse block that dodge has labled as "spare" it was burned out.
Gotta love those "spare" fuses, LOL.
Had a trailer light problem with a Cheby Z71 where there were no running lights at all on the trailer. Checked wiring harness, all fuses the manual had for anything to do with trailer connector. Very common for a fuse to blow when you submerge a boat trailer. Re-wired the whole damn trailer the day before having to drive 110 miles to a bass tourney with NO success.
Ended up taking my ex's Grand Cherokee to trailer the boat to/from the tourney.
Couple days later I started just pulling fuses and checking them and one marked "spare" was blown. Replaced it and VIOLA! had trailer lights...
Figures... Thanks Chrysler.
Old 07-21-2010 | 02:13 AM
sbsga's Avatar
sbsga
when my speed sensor went out the only thing i had was the abs light on and the speedometer and cruise control would not work
Old 07-21-2010 | 11:07 AM
Mike Williams's Avatar
Mike Williams
Replaced the speed sensor with no success. I guess we will double back and double check everything.
Old 07-22-2010 | 09:31 AM
Mike Williams
We still got the same code. P0501?
Old 07-22-2010 | 10:02 AM
jk360's Avatar
jk360
under the hood behind the battery there is a silver box with 2 wire plugs. detach the harnesses and check for moisture or corrosion.... if you can blow them out with a air hose.
Old 11-10-2010 | 09:40 PM
elite1msmith's Avatar
elite1msmith
what ened up being the problem?
also what "spare fuse" was it, where was it located?
Old 11-11-2010 | 08:27 AM
Mike Williams
Ended up being the computer. Had it replaced and all issues are gone. Im not really sure if it was a component failure within the computer or what. Its kinda hard to think it was a software issue with the age of the truck.
Old 11-11-2010 | 08:55 AM
RedTruck-VA's Avatar
RedTruck-VA
It's good it is fixed....
Old 11-11-2010 | 09:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
How much was a new computer for you. Where did you get it?
