ram rims
Old Jul 17, 2010 | 06:56 PM
'03 2500 8.0 V10's Avatar
'03 2500 8.0 V10
Default ram rims
does anyone know if 12.5 in tire will fit on a 2003 ram 2500 stock rims? they are 17"
Old Jul 17, 2010 | 09:45 PM
huseman808's Avatar
huseman808
if they are the wheels im thinking of... No, the tire would hit the upper control arm
Old Jul 17, 2010 | 11:07 PM
'03 2500 8.0 V10
im putting a leveling kit on i just want to know if it will just fit the rims. as long as the tire fits on the rim im good.
Old Jul 18, 2010 | 01:30 AM
huseman808's Avatar
huseman808
A level kit wont help you. I have a level kit on mine and was gonna run some 33x12.50x17 tires on the stock rims but there is not enough back spacing on them. I had to order a set of aftermarket rims to be able to run them.
PS
welcome to DF
Old Jul 18, 2010 | 12:36 PM
'03 2500 8.0 V10
ahhhh. i c. if i use a spacer kit wpuld that work? im a US marine so i dont really have the money to but new rims AND tires.
Old Jul 18, 2010 | 06:29 PM
AF_HEMI's Avatar
AF_HEMI
The rim itself isnt wide enough to safely run a 12.5 wide tire, let alone the rubbing issue with a rim without the additional backspacing.
If you put on 12.5 tires on the stock rim, not only will you rub the UCA, but you'll most likely pop the tire off the bead if you ever take some corners real hard or do anything major off road. You need at least a 9" wide wheel and a backspacing of 4.5". I beleive the stock ones are 8" wide and a 5.75" backspacing
Old Jul 18, 2010 | 06:52 PM
huseman808's Avatar
huseman808
AF is right. But even though it is not recommended I did have 33x12.50xr15 on my stock Dakota rims when i had a Dakota, which were only 8 inches wide(as are the Ram rims). i never had a problem though, so i gues it is up to you.
My crager soft 8 rims start at 70$ per rim and come in black silver white and chrome from summit racing. I bought a 17x9 inch rim with a 5.00" backspacing, no issues at all.
Old Jul 18, 2010 | 07:14 PM
'03 2500 8.0 V10
thanks guys ill definetly have to keep that in mind
Old Jul 18, 2010 | 09:01 PM
Big_Wheel's Avatar
Big_Wheel
well i actually have experience runing a 35" x 12.5" x 17 ( 2004 stock rim) and had no problems on road or offroad- i have a 3" body lift and leveling kit. Never had a problem rubbing or popping the bead.
Old Jul 20, 2010 | 08:05 PM
'03 2500 8.0 V10
awesome. if i do decide to run these on stock rims am i going to have to run spacers?
