Battery Life?
Old Jul 19, 2010 | 05:55 PM
rocket23's Avatar
rocket23
Exclamation Battery Life?
So what are the tell tale signs that a battery has met it's end? Mine was fine then wammy just like that.I couldn't even tell you how old it is.The truck just clicks and the tach and speedo go balistic,when I try to start.I thought this would be a gradual thing any ideas, sc flashpaq gave me a tranny mil, and three codes for a low battery. Battery is out and on a trickle charge.I'm stumped as too wnat else I can do,short of buying one.
Old Jul 19, 2010 | 06:49 PM
That1guy's Avatar
That1guy
Mine is a mopar battery and dated for july 2001. My truck is an 02 and has never had a problem so I dont know how long they last. Knock on wood.
Take the battery to a parts store and they can do a load test and tell you if you need a new one.
Old Jul 19, 2010 | 06:55 PM
brettj2408's Avatar
brettj2408
most batteries life expecatncy depends on weather conditions and starts
typical average is around 5 years.
i have seen oem batteries defective from the factory, and ive seen them last as long as 8 years
Old Jul 19, 2010 | 07:06 PM
rideon20z's Avatar
rideon20z
i had one for 6 years and one day i drove home from work after sitting all day started fine, ran home turned car off , and then back out to dinner , after dinner NOTHING . just like you said click click click ... and the tach and speedo did the same , after six years i guess it had its better days ! hopefully it didnt leave you stranded ?
Old Jul 19, 2010 | 07:12 PM
rocket23's Avatar
rocket23
Nah driveway thank god, went shopping some stop and go. Then sonic, then home.Thats where she died. Same mo. hhhmmm. Thanks dude. Similar is good. Means I may need just a battery, let's hope so.
Old Jul 19, 2010 | 07:55 PM
lxman1's Avatar
lxman1
Site Moderator
Might try to charge it then have it load tested. 5 years is average for an oem battery as mentioned above. Had the factory battery go over 8 yrs in a 96 Windstar that I had. Might have the alternator lead tested on the truck just to make sure it is up to par. Sounds to me like perhaps a plate has shifted and shorted out a cell.
Old Jul 19, 2010 | 08:46 PM
rocket23's Avatar
rocket23
yep,I'm of the same thought process, i'll leave it go. overnight then try it at napa.The alt will get tested later.
Old Jul 20, 2010 | 01:04 AM
rocket23's Avatar
rocket23
battery is fully charged, waiting on replacement battery. Perfect time for the power wire mod.imo.
Old Jul 20, 2010 | 01:05 AM
Marx's Avatar
Marx
i had the exact same problem my battery just died, no warning. but i know most 12v battery are just made up of 6 2v battery's so if i 2v bank fails it will still run on 10v witch is just enough to start the truck then when another 2v bank fails thats it.
Old Jul 20, 2010 | 01:20 AM
rocket23's Avatar
rocket23
i dunno what happened but it reads fully charged on the charger, i'll give it a try but waiting on daylight. gonna do a power wire while it (the battery) is separated from the truck. i'll shop for another battery soon, I don't screw around with batteries.
