Need help asap
Old Jul 20, 2010 | 09:56 AM
red ram ridin's Avatar
red ram ridin
Default Need help asap
Got a great deal on some sick bfg mud terrain ta km2's but they are 12.5 inches wide, can they fit on my stock 17s??????
Old Jul 20, 2010 | 10:06 AM
red ram ridin
ok according to this website the 35s will fit on a rim 8.5 inches wide to 11. The stock are 9 inches correct?
Old Jul 20, 2010 | 10:38 AM
ekgaudio's Avatar
ekgaudio
Fitting on the rim won't be the problem....it's whether or not they will rub? I believe you will need a wheel spacer to push the tire away from the suspension.
Old Jul 20, 2010 | 10:40 AM
dirtydog's Avatar
dirtydog
Moderate User
35 is not what you go by, the width of 12.5 is what you go by for fitment.
No, stock 20's are 8.5"(old ones), and 9" for newer style one's)
17's are either 8 or 8.5"???
12.5 width is a bit wide for stock rims IMO, but lots of guys have had no problems.
red ram ridin
Im putting a 6 inch on my truck as well as 1.5 inch wheel spacers. They will clear easy, but i talked to some tire people and they said they are too wide and will squeeze out and i will be riding on the sidewalls and they will wear bad and look bad
Old Jul 20, 2010 | 10:42 AM
red ram ridin
The rims are 8 inches wide. recommend 8.5 for 12.5. Its just so tempting because i can get 4 mud terrain km2s for 700$ with only 500 miles on them.
Old Jul 20, 2010 | 10:48 AM
ekgaudio's Avatar
ekgaudio
Since your saving so much on the tires why not throw in some rims too? I'm sure you can find some used or even new 17"s with the correct back spacing and width for a good price too.
Old Jul 20, 2010 | 11:01 AM
red ram ridin
yeah i think im gonna do that. I could buy 34s that fit mine tho for like 870 and im on a tight budget. im asking if shell go to 600 then i can get rims for 400
Old Jul 20, 2010 | 01:03 PM
SMKNRAM's Avatar
SMKNRAM
Just get new wheels and you will also save on not needing spacers!
Old Jul 20, 2010 | 01:15 PM
HammerZ71's Avatar
HammerZ71
Personally, I wouldn't do 12.5" wide tires on any wheel less than 9" wide. If you are on a budget, look at a set of black Crager Soft 8's in 17x9. They are steel so are a little heavier than an aluminum wheel, but no more so than stock wheels.
About $70 a piece anywhere online and the backspacing is perfect for that width tire on your truck. Hell, they ain't much more than a set of spacers at that price...
