3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I own a 2004 dodge ram 4x4 1500. I have blown the engine, my buddy has a 5.7 from a 2005 ram 1500. When i call the local salvage yards they tell me that the 2004 ram is a special year and will only take a motor from 2004. Is that true or will i just have to splice a few wires?
I believe MDS started in 06, so you should be clear there.
I talked to a guy who put an 08 Hemi into an 03 and he said everything bolted right up and all wiring worked
Could it be the difference between the MDS engine in 05 and the non MDS engine in 04 and earlier? That's the only thing I can see as a difference.
MDS started in 06 for 1500's only and can be disabled/removed (2500 and 3500 hemis do not have it).
