Right Hand Trailer Lights
Old 07-22-2010, 08:26 PM
marky0304's Avatar
marky0304
marky0304 is offline
Default Right Hand Trailer Lights
Anyone have any idea of why only the right hand turn signal doesn't work on both the 4 flat and 7 round trailer receptacles on my truck? Right hand works on the truck. The fuses are good. '03 1500 QC 4x4
Old 07-22-2010, 08:56 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
hmm...well does the right work or not????...lol
Sounds like a bad connection if the fuses are good.
bump for more answers.
Old 07-22-2010, 08:58 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
did you put a meter to the receptacles? If it's dead, gotta be a bad wire I would think...
Marx's Avatar
Marx
Marx is offline
just to make sure you know that there are separate fuses for the truck lights and the trailer light
Old 07-22-2010, 10:07 PM
marky0304's Avatar
marky0304
The 15 amp fuse for trailer right turn is good (#46 I think).
Old 07-22-2010, 10:09 PM
marky0304's Avatar
marky0304
The right hand turn signal for trailer does not work (both 4 flat and 7 pin round), but the right hand turn on the truck works.
Old 07-22-2010, 10:15 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
Same trailer?
Old 07-22-2010, 10:16 PM
Marx's Avatar
Marx
Marx is offline
i'd say i wire is loose then
did you read the fuse for continuity or just look at it because i have seen fuses that look perfect but are blown sorry to keep harping on this, just want to make sure
Old 07-22-2010, 10:38 PM
freestyledude's Avatar
freestyledude
freestyledude is offline
I would test the trailer, either with another truck or put power to the pin on the right signal
Old 07-22-2010, 10:44 PM
badblackram06's Avatar
badblackram06
badblackram06 is offline
Try this.. There are 2 green wires in the loom behind the trailer plugs. One is a solid dark green and the other is smaller solid light green wire. You will want to test light probe the light green wire. This is your Trailer right turn. If it doesnt illuminate the test light probe. you may have a broken wire.
For a last resort to get a right turn on the trailer, You may have to splice into the trucks right turn and run a wire from it to the trailers right turn wire for it to work. You might want to put an inline fuse so it will not harm your trucks right turn signal.
Quick Reply: Right Hand Trailer Lights
