I PowerBrake, computer derates Motor, Help !
Old Jul 23, 2010 | 10:09 PM
Pilotdriver's Avatar
Pilotdriver
Angry I PowerBrake, computer derates Motor, Help !
I powerbrake my truck on job sites but the computer decides that the use of 2 pedals iss a problem and derates the hemi down to junk running status and disables the crusie control too. When the code is cleared and the truck is started run and shut down for extended periods, several hours minimum then the truck will run fine. Until I get on another job site and control the truck by power braking and this starts all over. Can this 2 pedal detection by the computer be shut off with a programmer?
thx
Old Jul 24, 2010 | 12:13 AM
badblackram06's Avatar
badblackram06
Sounds like your truck is going into limp mode.. What model is your truck? What is the exact code that it is throwing? That may tell you whats wrong and why its going into limp mode. I'm sorry but i don't quite understand why you are power braking your truck? You say control the truck by power braking? Please explain.
I've always known power braking to be burning out, roasting the tires on the pavement, that sorta thing.
Old Jul 24, 2010 | 09:05 AM
Pilotdriver
the truck is an 04 2wd Ram 1500 5.7 Hemi/ automatic. with 4.10 gears. I don't have the code number but the dealer said when both the brake pedal and gas pedal are used the computer considers that a problem has occurred. And yes power braking is Old school and used for "burnouts" but it can be used to control the truck and have it move very smoothly in less than ideal traction conditions where you don't want to damage the driveline by any jerking motion or loss of traction. like I mentioned I do this on huge job sites that are dirt and gravel laydown yards where things like burms and curbs have been built that i need to get over without damaging them or my truck. the hemi's throttle response is so quick that it's almost impossible to control the tire spin in these conditions without the braking. Not doing this on pavement or for show, it' only done as a necessity. "Limp" mode describes it to a T , Dodge tech didn't mention the code number, just what it was doing.
THX
Old Jul 24, 2010 | 09:28 AM
dirtydog's Avatar
dirtydog
Moderate User
I've never even tried it with my truck but others have posted up doing powerbrake vidoe's????
If i could make a suggestion....Try pulling your ABS fuse and see if that doesn't solve the problem. Worth a shot anyways. i believe most Rams only have rear wheel ABS which is effin useless IMO unless your towing.
Old Jul 24, 2010 | 12:36 PM
Marx's Avatar
Marx
why don't you use second gear
Old Jul 24, 2010 | 03:53 PM
lxman1's Avatar
lxman1
Site Moderator
As a safety feature for the drive-by-wire, the brake pedal is supposed to override the gas pedal. But I think only if the vehicle is moving. Something that Toyota didn't program into the Camry hence the runaway vehicles!!
