Engine dies at red lights, need help
Old Dec 13, 2010 | 02:22 PM
  #21
broncoremy's Avatar
broncoremy
Originally Posted by herring_jerritt
broncoremy... i dont like correcting people but i have replaced the PCV on my 03 hemi soooooooo... im pretty sure it had one
My apologies. I stand corrected. Mrs Broncoremy reminds me that I am in need of continual correction so I am used to it. I don't mind being corrected, it is how I learn things.
The service manual mentions removing it from the IAFM? What is the IAFM?
Old Dec 14, 2010 | 06:32 AM
  #22
rocket23's Avatar
rocket23
any one have a picture on where exactly the egr valve is located, on the o6's??
Old Dec 14, 2010 | 11:35 AM
  #23
herring_jerritt's Avatar
herring_jerritt
here is a link to a pic of one, its hard to tell were your looking on the engine but you can see the oil filter and use it as a referance point, its goin to be on the front of the engine on the passengers side.
http://img14.imageshack.us/img14/4088/0313091632b.jpg
Old May 20, 2011 | 11:06 AM
  #24
wolf22m's Avatar
wolf22m
Originally Posted by broncoremy
Correct. No EGR or PCV valve on '03s.
Mine has a PCV valve that connects at the oil filler neck. Cleaned that out too as it was all crudded up.
Old Sep 12, 2011 | 05:19 AM
  #25
xoktoberskylinex's Avatar
xoktoberskylinex
Sorry this has taken so long, I don't have internet consently and I forget about this sometimes. Anyway, update on my issue. Since last time on here I have cleaned the throttle body, twice, replaced the EGR valve, the TPS, and the IAV. I also have had any leaks I had in the exhaust system welded up to be sure it wasn't a back pressure issue. I still have the problem of it almost stalling out at red lights, almost like a vapor lock on an older motor. It doesn't seem to happen as often now, but my truck seems to like 500 instead of 600 RPMs for an idle now.
Old Sep 13, 2011 | 01:40 PM
  #26
rocket23's Avatar
rocket23
I would flashpaq the motor, that would adjust your idle too stock. 5oo rpm seems low. A sc tune will help I'm betting.
Old Sep 15, 2011 | 03:46 AM
  #27
xoktoberskylinex
I just need to find a place to tune it up then, I was told the '04's don't have a tuner.
Old Sep 15, 2011 | 12:34 PM
  #28
rocket23's Avatar
rocket23
My truck is a rock steady 800 rpm. I checked the day after I commented . Hope it helps.
