broken off bolts inside rear diff
Old Aug 11, 2010 | 10:23 AM
  #31
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by brettj2408
#27 is the axle pin (pinion shaft bolt) not what he needs
#24 is the ring gear bolts which he needs
ahaaa, you are correct my friend. #24 is right next to the axle pin and I associated it with that. #27 is skinnier just llike it should be which would be the pin bolt.
Atleast he has ordered the right parts and thanks for pointing that out!
Old Aug 11, 2010 | 10:24 AM
  #32
brettj2408's Avatar
brettj2408
these lol
no problem dirty
Old Aug 11, 2010 | 11:01 AM
  #33
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well Im glad I put up the exploded view......LOL
Old Aug 11, 2010 | 11:48 AM
  #34
abarmby's Avatar
abarmby
The OP should easily be able to get parts for his ram in Holland.
I have approached my local Chrysler dearler over here in England, and he orders parts for me from Holland.
They get over nighted to the UK and I usually have OEM parts within 3-5 days.
I've bought everything from OEM air filters, to cv boot joint kits and other stuff.
So to the OP, approach your local Chrysler dealer and give him your VINnumber.
They will then get you your parts easy.
They might be very pricy......but they will be the correct parts.
Hope this helps?
Al.
Old Aug 12, 2010 | 07:44 AM
  #35
rickwolting's Avatar
rickwolting
you are right!!,
i already got the parts, as you can read in threat 24 ,
i just finnised installing the new bolts, torque'd them to the right torqeu, put the cover back on put the oil in, and them found out that the batery was flat...
i put the axle on stands last night and in order to rotate the wheels i left it in Drive, which means i have to put the ignition on, forgot to turn it of last night, dumb ***.
but in al the axle is finished, and with help of you lot!!
thanks a bundle!!
Rick,
Old Aug 12, 2010 | 09:01 AM
  #36
dirtydog's Avatar
dirtydog
Moderate User
Well that was quick. Glad to hear everything worked out. Hopefully everything goes well driving down the road..i.e. noises..etc,.?
Old Aug 12, 2010 | 03:14 PM
  #37
rickwolting
i drove it today, and now noisese what so ever,
however on the front there seems to be a skweeking noise, witch changes whem you drive over a speed bump, in other, when the weight is off the wheels it becomes less, and when the weight is more (coming down on the front) it becomes a bit louder,
it sounds as if something rubbery is skreaming a bit.. dont now what that is..
do you need to grease any parts in the front?
rick,
Old Aug 12, 2010 | 04:06 PM
  #38
RedTruck-VA's Avatar
RedTruck-VA
A common source for a front end squeek on a two wheel drive is ball joints. Good luck...
Old Aug 12, 2010 | 06:37 PM
  #39
rickwolting
all check that out, but it is not squeeking whill bouncing, but when the wheels are turning, it just changes when the load is on or off...
Old Aug 12, 2010 | 06:51 PM
  #40
RedTruck-VA
Jack the wheel off the ground about 3" and stick a bar under the tire and pull up sharply to see if the tire (ball joint) will move. It is about the easest way to check. Good luck...
