gross max train weight
Old Aug 12, 2010 | 05:51 PM
neil300zx's Avatar
neil300zx
Default gross max train weight
Please could someone confirm the gross maximum train weight for the ram 1500 sport 4.7
gross weight of truck = 9500lbs?
towing capacity =2700lbs?
= gross max train weight 12,300lbs ?
is this correct
Cheers
Neil
Old Aug 12, 2010 | 06:34 PM
MikeHTally's Avatar
MikeHTally
Well, The gross weight of the truck can't be that much. That would be a payload of +/- 3,000 lbs and it isn't that much. Tow capacity is usually in the neighborhood of 7,200 lbs or so.
You should find the GWR and GCWR on the door placard.
Oh, and Welcome to DF!
Old Aug 13, 2010 | 02:37 PM
neil300zx's Avatar
neil300zx
Hi and thanks for the welcome all the way from blighty (over the pond)
Ive taken this from the info i got using the vin number from the website i found on this forum, the ones ive marked with asterix is where i have done my sums from, gross combined weight rating i assume is the payload and max weight of truck, then ive added the towing allowance which i found elsewhere on the forum which is 2700kg = 5952lbs. sorry i was using lbs and kgs and added together doh!
I make that a total of 15,452 = 7000kgs which to me sounds in the right ball park but i need to be sure before i purchase the veichle
Technical Specifications
Description Value
Vehicle Name Ram 1500 Pickup
Body Style Quad Cab 6'3" Bed
Body Code 140" WB
Drivetrain Rear Wheel Drive
Passenger Capacity 6
Gross Axle Wt Rating - Front (lbs) TBD
Gross Axle Wt Rating - Rear (lbs) TBD
Curb Weight - Front (lbs) 2686
Curb Weight - Rear (lbs) 2198
Gross Vehicle Weight Rating Cap (lbs) 6650
EPA Fuel Economy Est - City (MPG) 15
EPA Fuel Economy Est - Hwy (MPG) 19
Gross Combined Wt Rating (lbs) 9,500 ********
Dead Weight Hitch - Max Trailer Wt. (lbs) 5000
Dead Weight Hitch - Max Tongue Wt. (lbs) 500
Wt Distributing Hitch - Max Trailer Wt. (lbs) TBD
Wt Distributing Hitch - Max Tongue Wt. (lbs) TBD
Fifth Wheel Hitch - Max Trailer Wt. (lbs)
Fifth Wheel Hitch - Max Tongue Wt. (lbs)
Thanks
Neil
Old Aug 13, 2010 | 03:05 PM
Marx's Avatar
Marx
train weight?
Old Aug 13, 2010 | 03:07 PM
neil300zx's Avatar
neil300zx
Train weight in the UK = Maximum combined weight of truck, payload and trailer
Old Aug 13, 2010 | 03:13 PM
hoss67's Avatar
hoss67
19 MPG highway!!!!!!! jesus i only get 13.5 with my 4.7 and only 15.5 with my normal size tires on mine..
Old Aug 13, 2010 | 03:29 PM
Marx's Avatar
Marx
truck 5500lb
trailer 8300lb with 800lb tongue
1000 lb in the bed
and your pretty much maxed out
of course you must have the proper equipment on the truck to tow 8000lb, factory hitch will tow 5000lb with 500lb tongue
4x4 minus 500lb
20" rims minus 1000lb towing
theses are rounded off numbers
Old Aug 13, 2010 | 03:50 PM
MikeHTally's Avatar
MikeHTally
My truck has a GVWR of 6,650 lbs. Payload is about 1,200 lbs giving a curb weight in the 5,400 lb range. The tow rating is 7,800 lbs so the GCWR would be about 14,450 all-up.
That 9,500 GCWR you're showing would make for a towing capacity of about 4,000 lbs, which sounds low. GCWR is the truck, your "stuff" AND the loaded trailer. GCWR= "train weight" probably. Is your truck the 4.7?
DUH! I missed the displacement in your first post. Maybe that's why your GCWR is only 9,500 lbs.
