Is this a good receiver hitch? Stock maybe?
Old Aug 13, 2010 | 01:13 AM
2001Ram's Avatar
2001Ram
Default Is this a good receiver hitch? Stock maybe?
I found this on Craigslist, and he doesn't want much for it. Was this like stock. Would it be able to pull a boat ect?
Thanks,
Ryan
Old Aug 13, 2010 | 01:24 AM
scwpd's Avatar
scwpd
i have not looked under my ram to see what it has but it looks just like the one i put on my dakota. it should be good for 5k pounds.
Old Aug 13, 2010 | 01:25 AM
2001Ram's Avatar
2001Ram
The ad says it came off a 2004 Dodge Ram, so I think it will be ok. He wants $40 for it. Good deal right?
Old Aug 13, 2010 | 01:34 AM
Marx's Avatar
Marx
stock
yep 500lb tongue and 5000lb draw
or
800 tongue and 8000lb with a weight distribution system
thats what mine says
Old Aug 13, 2010 | 09:18 AM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, they are about $100 new http://www.dodgepartsstore.com/produ...roducts_id=715
^^They also give the specs on what you can tow as well.
Here's the wiring kit http://www.dodgepartsstore.com/produ...roducts_id=720
I hear you have to pretty much take the rear bumper off to get it installed.
Old Aug 13, 2010 | 11:08 AM
tlawre87's Avatar
tlawre87
The difference is that the piece there bolts on to the support that runs from the frame rail to under the bumper. If the truck had a factory tow package that piece is welded to it.
Old Aug 13, 2010 | 01:36 PM
RedTruck-VA's Avatar
RedTruck-VA
Thanks,
Ryan
Ryan,
That is the same as the OEM Class III hitch I took off my 03. The only difference is I want $75 for mine.
Old Aug 14, 2010 | 02:36 AM
scwpd's Avatar
scwpd
if you buy it just make sure it comes with the bolts. the dakota i had there were two bolts that you had to fish threw the brace and they had a square piece of metal on them so you could tighten them down with out them spinning.
