05 Hemi stalling
Old Nov 8, 2005 | 01:30 AM
lawdogdusty's Avatar
lawdogdusty
Default RE: 05 Hemi stalling
Ok, 2 more 02 sensors and they say its good to go..We shall see.......
Old Nov 8, 2005 | 03:12 PM
Avanti's Avatar
Avanti
Does the engine "roar" for the first few seconds of driving after first being started when cold? Mine does this for about half a block or so. A roar is the only way I can describe mine, but it doesn't stall. This seems to be when yours does. The noise seems curious and I've thought it must be some kind of cold-start setting to avoid typical cold-start stalling.
Still weird. Just something else to compare your "staller" with.
Good luck.
As you've seen, the O2 sensors shouldn't be the culprit.
Old Nov 15, 2005 | 05:20 AM
SIXPACKSUCKER's Avatar
SIXPACKSUCKER
yeah i had to take my 05 hemi in for some tranny issues and asked the master tech about the stalling, my truck had done it once i cranked the wheel till i hit the releif valve and he said basically due to the fact that the truck is all electronic throttle control, and electronic idle, when you crank it over like that, it puts a stress on the motor causing the idle to go up and the computer doesn't understand whats causing the raise in rpm and it just shuts off the motor.
Old Nov 15, 2005 | 09:13 AM
stevearino's Avatar
stevearino
ORIGINAL: Avanti
Good luck.
That sounds like the clutch fan. Mine does that too. In fact, I've owned several cars/trucks that have had the fan kick on when first starting, then driving for a block or so. Sounds like a blower! No stalling on mine yet. I only have 450 miles though.
