smoke from exhaust on WOT
Old Aug 27, 2010 | 09:16 PM
zero413's Avatar
zero413
Default smoke from exhaust on WOT
I searched the forums couldnt find anything, anyway i got an 04 ram 1500 hemi with 77k on it, i got into to after work and drove not too heavy on the peddle but good enough, when i stopped it seemed to sputter a bit but rpm didnt move much, stepped on the gas seemed to hesitate a bit but ran fine after a few seconds. When i got to the highway i gunned it mostly for fun but also to just open it up, when i looked back i saw a noticable cloud of smoke, looked kind of greyish but couldnt really tell, it did it again when i floored it about a quarter mile up. I dont think im loosing any antifreeze goin to check the oil out in the morning, but i just did a change a month ago and no water/milkyness to the oil, i use mobile 1 HP. The only code i have is the evap leak, which im just being lazy on to fix. Any suggestions?
Old Aug 27, 2010 | 10:13 PM
Matt99's Avatar
Matt99
mine puts a little bit of smoke out on WOT, im pretty sure its normal unless it looks like a smoke bomb back there
Old Aug 27, 2010 | 10:20 PM
zero413's Avatar
zero413
it kinda looked like a lot, kinda of like your breathe in the winter best way i can describe it, was about 100 feet of WOT when i looked back and saw it kinda scared me a bit so i let off the throttle. Ive seen a lil smoke when i went WOT in the past on this truck and my 03 dak 4.7 but not this much.
Old Aug 27, 2010 | 11:36 PM
Matt99's Avatar
Matt99
hmm you said white smoke? if its white, some oil is burning somewhere....compression test?
Old Aug 28, 2010 | 12:05 AM
Marx's Avatar
Marx
did you let it warm up before you were givin'er, could be unburned fuel but not sure
Old Aug 28, 2010 | 12:16 AM
dirtydog's Avatar
dirtydog
Moderate User
It's not uncommon for veice to coug up som smok when yu romp on it. It's likely excess carbon build-up inside the combustion chamber or from oil being sucked backtrough your pvc and going down or intake.
I pulled my TB off at 8kmi and the backside of the butterfly plate was all gunked up.
Old Aug 28, 2010 | 12:48 AM
zero413's Avatar
zero413
Wasn't warmed up maybe five min from when I started it. It does use oil already brought it to a dealer once said that the oil consumption was in normal range. I was planning on have a full look over done on it since my warranty is almost up might as well get the compression test done.
Old Aug 28, 2010 | 06:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said before, either oil getting past the rings and being burned and expelled or fuel not being burn off
Old Aug 28, 2010 | 10:13 AM
zero413's Avatar
zero413
yeah the dodge tech when i brought it in said 1qt per 3000 miles is acceptable. i still want to get the compression test done. I just got nervous never seen it smoke that much before, and i drive my truck hard
