not quite level and it's irritating me
Old Sep 8, 2010 | 09:43 PM
  #31
bigtigga84's Avatar
bigtigga84
Front Fender
Rear Fender
Old Sep 8, 2010 | 11:33 PM
  #32
Matt99's Avatar
Matt99
so your rear is exactly 1in higher than the front. I have heard of people removing an overload spring if you dont tow, that would be a 1/2in, spin the tires a bit and lose another 1/2 inch and there you go!
Im trying to think on how to get you that extra inch...everyone else with the bilstiens have been closer to 3in total lift
Old Sep 9, 2010 | 12:14 AM
  #33
bigtigga84's Avatar
bigtigga84
honestly, i think im the first with a reg cab short bed to install them. like i've said in other posts, i think the angle is steeper on them. Don't know if that makes sense or not. shocked me it was exactly an inch difference, couldn't do that again if i tried. have considered beltech drop shackles. says 1.25 drop on their page. if it is 1/4" shorter in the rear i could just put spacers in to get it as close as i could. just glad i finally decided to take pics so ya'll didn't think i was nuts lol.
Old Sep 9, 2010 | 12:17 AM
  #34
bigtigga84's Avatar
bigtigga84
it's way to easy to spin the tires now
Old Sep 9, 2010 | 08:34 PM
  #35
BigHorn777's Avatar
BigHorn777
it is not that bad, looks like your worried over a 1/2 inch..just make sure the snap ring on the front shock is all the way up as I posted earlier. Crawl under the truck with a flash light and look up the shock. If it isn't, it is a like a half our job to move them.
Old Sep 9, 2010 | 11:12 PM
  #36
Marx's Avatar
Marx
Originally Posted by BigHorn777
it is not that bad, looks like your worried over a 1/2 inch.. I wouldn't be worried about that, if you are drop the snap ring in the front 1 notch and you will be level... Easy fix and will take like 30min...
i think his front is 1/2 lower than the back
OP are you sure there are not lift blocks in the rear? that leaf spring pick looks like there might be something in there
Old Sep 9, 2010 | 11:45 PM
  #37
bigtigga84's Avatar
bigtigga84
here's a better pic of the springs. looks to me like factory spring seat.
if it was just a half inch i wouldn't care, but it's enough that it is noticeable.
Old Sep 9, 2010 | 11:48 PM
  #38
Marx's Avatar
Marx
ya does look factory
Old Sep 10, 2010 | 12:12 AM
  #39
bigtigga84's Avatar
bigtigga84
yeah, think im gonna go with the drop shackles from beltech and they add shims under the springs if i need too.
Old Sep 10, 2010 | 06:26 AM
  #40
Matt99's Avatar
Matt99
lol lower it and lift it? I hope your u-bolts are long enough to play with shims
