Trailmaster Lift Problems!!!!
Old Sep 10, 2010 | 04:36 PM
Paratrooper's Avatar
Paratrooper
Default Trailmaster Lift Problems!!!!
OK just got my truck back from having the trail master lift installed and the passenger side tie-rod end is within 1/128th of an inch from the stock 20" wheels not touching ( anymore) but way too close for comfort. also now i just realized my 17" wheels wont fit on the truck because the offset touches the tie-rod and personally i think if i threw on some tires that the girth of the tire would hit the knuckle...... any suggestions???
the guy i had do the lift has been doing it since he was 15 and owns his own truck repair business
Old Sep 10, 2010 | 08:27 PM
Paratrooper
ok so i figured out the problem, the kit is fine, its just they screwed up on what it fits on. the kit stated it will fit a stock 2008 1500 with the stock wheels.... but it also says not to use a wheel with a back spacing of more than 4.75 well the stock 20" wheels are 5.75 back spacing wtf already!!!! and the 17" wheels dont fit either cus they say in the instructions u cant go smaller than a 18" wheel since it will hit the tie rod. what dodge was trail-master using when they said this fits on a stock truck since no stock wheels really work with this kit!!
Old Sep 11, 2010 | 09:26 AM
Matt99's Avatar
Matt99
you need to call them and let them know....pics also
Old Sep 11, 2010 | 01:16 PM
Paratrooper
here are the pics u cant tell from the pic but they dont rub but i mean only by 1/128 of an inch
Old Sep 11, 2010 | 06:10 PM
Matt99's Avatar
Matt99
Did you get an alignment? Im wondering if that would help
I would just buy a set of wheel spacers...easy and cheap and no more worries! It would be the easiest fix I think
BTW it looks good man, how much it set you back?
Old Sep 12, 2010 | 04:59 AM
Paratrooper
yeah got an alignment and it didnt help at all what u see is after the alignment. so im gonna rip trailmaster a new one. they said i could use 35" tires on stock wheels but as you can see that bull ****
Old Sep 12, 2010 | 11:05 AM
Matt99's Avatar
Matt99
Let us know how it goes
Old Sep 12, 2010 | 08:21 PM
Paratrooper
btw i was able to get the lift 4 $880 its actually a very well built and put together lift kit for the price, granted a BDS kit is prob better but im not really wheeling this although i feel that this kit is def strong enough to take that kind of abuse just wish the knuckes were set up so i could use the stock wheels
Old May 11, 2011 | 02:40 PM
in5ane1's Avatar
in5ane1
Any update on this? I was thinking about getting the same lift and putting some aftermarket wheels on mine. I have a 2008 ram 1500 QC 4x4 with 20's. Also, where did you find that kind of deal?
Old May 11, 2011 | 02:52 PM
HammerZ71's Avatar
HammerZ71
MOST every kit I've seen that allow you to run 35s with the stock wheels supply their own tie rod ends that are shorter and a lot beefier (thicker) than the stock ones (and are also GREASABLE).
They require you to cut some off the end of each tie rod to move them in about 1 1/2" on each side. As you can see from the OPs pic, there is still plenty of thread left and especially so because the supplied ends are a bit shorter.
I know I had to with my Rancho kit. As you can see (in my pic) Rancho supplies Moog ends with grease nipples. I didn't use the stock wheels, but with my Mickey Thompson wheels there is a TON of room.
Now I ain't trying to sway you on what lift to buy, but these are REPLACEMENT ends that Rancho sent me after one of mine failed - 5 YEARS AFTER I INSTALLED THE KIT. They not only sent me the one to replace the bad one but ANOTHER for the other side - FREE OF CHARGE!
