Air conditioning related to window defogger
Old Sep 16, 2010 | 06:59 PM
ve7dui's Avatar
ve7dui
Default Air conditioning related to window defogger
I have noticed that the A/C runs while the window defogger is enabled.
Is this normal, has anyone noticed this?
2008 1500 TRX4 5.7 Hemi
Matt
Old Sep 16, 2010 | 08:12 PM
That1guy's Avatar
That1guy
Yes everything does it. It dries the air so it removes the moisture from the windshield. It wouldn't work as well with out it.
Old Sep 16, 2010 | 09:05 PM
MikeHTally's Avatar
MikeHTally
Been that way for many years.
Old Sep 17, 2010 | 02:52 AM
ve7dui's Avatar
ve7dui
thank you for the quick reply
Old Sep 17, 2010 | 06:23 AM
abarmby's Avatar
abarmby
Yep....so remember, if you want to save a few MPG's............ Turn off your de-fogger as the AC is running.
Al.
Old Sep 17, 2010 | 09:10 AM
Paratrooper's Avatar
Paratrooper
anyway to disable the A/C from coming on automatically ??
Old Sep 17, 2010 | 09:31 AM
abarmby's Avatar
abarmby
Just switch the defrost to off, as there is no way to disable the AC when the heater is on the defrost setting that I know of.
Al.
Old Sep 17, 2010 | 01:07 PM
That1guy's Avatar
That1guy
You really need the compressor on. Really no point to bypass it.
Old Sep 17, 2010 | 01:23 PM
Bent's Avatar
Bent
the compressor will have a low-ambient temp. cut-out switch anyways, so when it's cool enough outside, you're compressor won't start regardless.
