Compatible rear ends
I have a 2002 1500 4X4 quad cab and the rear differential is shot. I would like to find an entire rear end at a salvage yard and just switch it out with mine. I know the rear has 3:55 gears but I was wondering what other years of dodge rear ends with the same gear ratio would be compatible with my 2002. Ive called the dealerships and have recieved conflicting info.
Thanks for any help
Mike
Thanks for any help
Mike
Thanks for any help
Mike
Thanks for any help
Mike
3:55 gear is very common, although I have never seen anyone with a LSD with a 3:55 gear. The 02 if I'm correct has disc rear brakes and any 02 thru 05 rear axle should bolt up. Many of us have upgraded using a aftermarket differential and a deeper gear. Of course yours being 4wd would also require changing the front gear to match whatever gear you choose for the rear. Good luck..
Hello & Happy New Year...
Im upgrading my 2003 Durango (4.7Lt) 2x4.
I'm looking for a Posi_Lock OR LSD Diff that'll fit my truck...
I've been told that the Dana 44 should do it. Yet as I look around I've found different ratios of the Dana 44 (9.25, 9.22. series 30, etc...)
This starts to lead towards a little confusion...
Any help...
Any help...
Dodge uses a AAM differentials not Dana. It should be a 9.25 AAM diff.
http://www.demandaam.com/product-cat...nion-gear-sets
Trending Topics
Mike,
