Rear leaf springs are shot...
Old 09-28-2010 | 01:27 PM
Ratbike1's Avatar
Ratbike1
Originally Posted by 03DodgeHemi
They aren't really stiffer just have more play in them, bounce more and squeak. I was thinking of going to a junk yard and trying to pull some off if I found a yard with an 02-06 ram.
U sure youre not hearing U-Joints? Sounds like it to me- bounce and squeek that is.
Old 09-29-2010 | 12:24 PM
03DodgeHemi's Avatar
03DodgeHemi
I actually got it checked out by the garage that rotates my tires and they said the leaf springs were making this noise because they looked shot from towing too much is what they told me...
Old 09-29-2010 | 03:46 PM
MikeHTally's Avatar
MikeHTally
I'm officially confused. First, they were stiff and squeaking, now they're loose and squeaking? Bounce is controlled by the shocks. If you're getting bounce with the new shocks, there is something wrong there.
The only rear squeaking I get is from a good Mexican dinner
Old 09-29-2010 | 04:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If the rear is bouncing then it could be bad shocks, warped rear rotors or maybe you just need to put two 80# bags of concrete in the bed and over the axle.
Old 10-06-2010 | 10:16 PM
03DodgeHemi
If I found other leaf springs what years would work? 02-06 1500s? And what about from a 2500? Would any of those work?
Old 10-06-2010 | 11:15 PM
RedTruck-VA's Avatar
RedTruck-VA
I would recommend using the WD-40 to chase down the squeak and then graphite it once I found the problem. I don't really buy into worn out springs as often as is suggested on this forum.
Old 10-07-2010 | 02:43 PM
03DodgeHemi
Yeah it rattles in the back though now as well. I took it in to a shop already because I thought my bed was loose which was causing the rattling, but they said it was my leaf springs making all the noise...
Old 10-07-2010 | 04:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I just seen a set of leaf packs with an add-a-leaf (2" lift) on CL for 50 bux
Old 10-08-2010 | 02:57 PM
03DodgeHemi
Where at?
Old 06-16-2011 | 12:16 AM
MBM20's Avatar
MBM20
Leaf springs do squeak rattle when worn out. I just changed mine out last week with ones from the scrapyard 100 bucks a side. Make sure you have tall jacks if your doing the work yourself you want your truck to be as high off the ground as possible so your axle can go as low as possible found that out after installing the first side.
Quick Reply: Rear leaf springs are shot...
