fan blower
Old Oct 3, 2010 | 04:07 PM
mike_r's Avatar
mike_r
Default fan blower
Hey ya'll. I just noticed that my blower for the air conditioning and the heater only works on full. The other 3 speeds just are off. Where do I start to diagnose this. Does the fan have 4 different speeds, or does the **** have resistors in it?
All your help is greatly appreciated.
Old Oct 3, 2010 | 08:38 PM
PETE_YK's Avatar
PETE_YK
Those are the exact symtomes of a blown resistor. Earlier rams/durangos and dakotas were never known for keeping resistors lol.
Old Oct 3, 2010 | 09:17 PM
Marx's Avatar
Marx
ya theres a resistor bank for the 3 speeds, i believe its right next to the blower under the passenger dash, there are service manuals (courtesy of weedahoe) https://dodgeforum.com/forum/3rd-gen...-download.html
Old Oct 4, 2010 | 09:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said, check the resistor. To do so go get your voltage meter and test each prong for voltage as you adjust the **** on the AC controls. At full speed the motor gets 12v. At lower speeds it gets less. If you need a part number for a new resistor then look in the links I have listed below and get the one for your truck.
Old Oct 4, 2010 | 11:16 AM
mike_r's Avatar
mike_r
Can I get to the bank from under the passenger side dash, or do I have to pull the dash? Doesn't it seem weird that all the resistors went out at once?
Old Oct 4, 2010 | 02:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It is a resistor block and net several resistors. Im not sure where it is under the dash. Look in the links in my signature and download the Service Manual for your truck and use it to help you out.
Old Oct 4, 2010 | 02:55 PM
mike_r's Avatar
mike_r
Just looked at the manual. The resistor block is right next to the blower motor. It's really easy to get to from under the glove box. Just 2 screws and it's out. Pix provided. I'm anxious to see what a new one of these costs.
Old Oct 4, 2010 | 03:15 PM
mike_r's Avatar
mike_r
Just called the local dealer. They want 118$ for one of these. They're going for about 30 on ebay. I think i'm going to go with an ebay one.
Old Oct 4, 2010 | 11:21 PM
Marx's Avatar
Marx
you could also check your local junk yard
Old Oct 5, 2010 | 08:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree with ebay or the junkyard but keep in mind there are links in my sig link for the Parts Manuals you can download and get P/N's and search online that way also.
