08 Ram 1500 front suspension clunking
Old 10-13-2010, 01:06 AM
bkwood's Avatar
bkwood
bkwood is offline
Default 08 Ram 1500 front suspension clunking
I have a 2008 Ram 1500 4x4 that makes these "clunking" noises when I hit any bumps or inconsistencies in the road. It's driving my crazy and I'm wondering if anyone has any insight as to what it could be. I did put a 2 in. leveling kit on the front as well.
I'm thinking it could be a number of things like bad strut, wheel bearing, swaybar endlinks...etc..
Has anyone had this similar problem? Any help would be great! Thanks!
Old 10-13-2010, 08:08 AM
Got_Hemi44's Avatar
Got_Hemi44
Got_Hemi44 is offline
Any vibration in the steering wheel when it clunks? Also push up and down on the front bumper to see if it blinks while parked.
Old 10-13-2010, 11:53 AM
bigmac18's Avatar
bigmac18
bigmac18 is offline
Since you put the 2" level on, It could be the Upper control arm hitting the shock mount bucket when your suspension travels?
Old 10-13-2010, 03:29 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You could always take it to a frint end shop to let them look it over and tell you what needs replacing. Then when they give you a quote you can make an excuse and replace it all yourself for a fraction of the cost and take it back to them to get it aligned
Old 10-13-2010, 04:11 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
This is one of the most common problems out there!
Have you peeked at your struts to see if there's any leaking gojn on? Spacers do limit travel and are not in total agreement with stock length struts. HERE is an explanation of how the suspension works with the different types of leveling kits.
Old 10-13-2010, 04:34 PM
daddykirbs's Avatar
daddykirbs
daddykirbs is offline
... or a loose bolt on the bottom of the front shocks.
Old 10-13-2010, 05:49 PM
KY BIGRAM's Avatar
KY BIGRAM
KY BIGRAM is offline
I've noticed this on my '04 as well and narrowed it down to the sway bar linkage. It has done it for a long time and it does suck. Those link are in excess of $100 and I don't see why they have a nuckle at the ends.
Anyone see a reason why this cannot be a solid link?
Old 10-13-2010, 06:07 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Ive got the links off my truck when i put longer ones one for my susp lift. They are out sitting in the shop.
Old 10-13-2010, 07:22 PM
KY BIGRAM's Avatar
KY BIGRAM
Does the new ones have the pivot? Curious,,,,,,,
Old 10-14-2010, 06:01 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
New ones? Pivot? I assume you mean the new set I added with my susp lift? Yes that have the rubber covers with the parts that pivot or swivel. They came with my Rough Country susp lift and are just like OEMs but longer due to the cross member drops.
Quick Reply: 08 Ram 1500 front suspension clunking
