PLEASE HELP!!Changing front strut,cant remove lower strut bolt!!
Old Oct 25, 2010 | 09:31 PM
stimpytheman's Avatar
stimpytheman
Angry PLEASE HELP!!Changing front strut,cant remove lower strut bolt!!
Hello everyone, newbie here about to pull my hair out!!! I have a 2006 dodge ram 1500 4x4 SLT and i'm trying ...key word...TRYING ...to change my front coil over struts, i removed the top strut nuts (3), then, tried to removed the bottom strut nut that connects the strut to the lower control arm....aint happenin!!! removed the nut, sprayed the hell out of it with PB blaster, and tried unbolting it,...hitting it with a hammer,...and so on, wont move, tried working it back and forth with a ratchet hoping to break it loose, wont move ....running out of options, this is my daily driver and i need it done!!! please help, and i was reading the shop manual and it said once that is done to removed caliper/rotor, seperate top ball joint, and remove....any short cuts or is that it...please help, thanks in advance...
Joe
Old Oct 25, 2010 | 09:35 PM
horatio102's Avatar
horatio102
Bigger impact gun, bigger breaker bar, or a torch.
I'd call it a night though, and continue after buying a spare bolt.
Old Oct 25, 2010 | 09:41 PM
bello926's Avatar
bello926
i had the same problem on my 06. take your impact and spin that bitch for like 5 min and take a air chisel with a pointy bit and it will pop right out
Old Oct 25, 2010 | 10:01 PM
stimpytheman
Default i will try all the above..
dont have an air chisel but i do have an impact 1/2", i will mess with that, but....where do i get another bolt from other than the stealership...what size? approx. cost? broke off my arss...lol, thanks for the replies so far guys, i appreciate it...
Old Oct 25, 2010 | 11:44 PM
Matt99's Avatar
Matt99
can you take a picture for us?
if you have any harbor freights around you i bough an air chisel for $15 and have used it quite a few times....one of the bolts on my fourwheeler a arm broke and I ground an X into the top of the bolt, cutting the head into 4 sections, and then and air chisel to break each section off...then the pointed bit to press the rest of the shaft out
Old Nov 15, 2010 | 03:09 PM
barksatbirds's Avatar
barksatbirds
Did you ever find a solution to this?
I have the same problem.
Old Nov 16, 2010 | 09:50 AM
blakern's Avatar
blakern
I have an 06 as well and im trying to level it! Already broke one spindle and now cant get the bolt out either! Ive lifted/leveled 3 trucks before, and lowered 3 cars and 1 suv, but ive never had so much damn trouble before, this suxs!!!!!!!!!!!
Old Nov 16, 2010 | 11:36 AM
barksatbirds
After much searching, I found the following:
https://dodgeforum.com/forum/3rd-gen...-2008-4x4.html
This particular tutorial covers completely removing the tension on this bolt.
I have not had a chance to try it, but I plan on doing so this weekend.
I hope that helps you/(and me) out.
Old Nov 16, 2010 | 01:54 PM
blakern's Avatar
blakern
Mine had 0 tension on it and still wouldnt come out. I beat the hell out of it, used an impact, tryed a C clamp to press it out. Nothing worked. There was just to much corrosion built up in the metal sleve thats inside the bushing.
This is how mine came out. Sawzall to the rescue!
Old Nov 16, 2010 | 04:45 PM
crazyandy202's Avatar
crazyandy202
I cant even get the nut off of the bolt I am having the same problem!
