This is quite aggravating
Old Oct 26, 2010 | 01:57 PM
RU4HEMI's Avatar
RU4HEMI
Default This is quite aggravating
Just recently my '07 hemi ram 1500 starting dinging like the enginge light just came on, but doesn't, today i get in and drive to pick some things up and i have no acceleration at all, it'll hit 2500 rpms before it even starts to move, and it will just stay at whatever rpm it was at last when driving after i release the gas. When i'm parked and shift from park to the other gears it shifts rather hard to the point it rocks my truck...wtf is going on?
Old Oct 26, 2010 | 03:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would start by resetting the PCM and see if that clears it up. Have you done regular scheduled and preventive maintenance on this truck?
Old Oct 26, 2010 | 03:43 PM
RU4HEMI's Avatar
RU4HEMI
I have, it did something similar to this not too long after i first bought it back in January so i took it into the dealership and they couldn't find anything wrong with it. The only difference between then and now is at that time it wouldn't go faster than 30mph.
Old Oct 26, 2010 | 03:48 PM
Rich 2500's Avatar
Rich 2500
Have you checked to see if it's throwing any codes?
Old Oct 26, 2010 | 03:53 PM
RU4HEMI's Avatar
RU4HEMI
After the first time yes and nothing came up, but i haven't gotten to today since i've been stuck at work, as soon as i get off though i will
Old Oct 26, 2010 | 05:44 PM
9511234's Avatar
9511234
Check for codes and all that good stuff. How many miles on your truck?
Resetting would be good, too. You might just check plugs and wires to make sure nothing is loose. Something as simple as a spark plug could cause some of these symptoms.
Does your engine light come on before starting?
Old Oct 27, 2010 | 06:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
if it will nto go faster than 30 then I would say to take it by a transmission shop and let them scan the TCM and see if they pick up any codes
Old Oct 27, 2010 | 01:19 PM
RU4HEMI's Avatar
RU4HEMI
I'll go over everything again today just to double check cause today its acting perfectly fine again. Still taking it to the shop
Old Oct 28, 2010 | 11:50 AM
Rich 2500's Avatar
Rich 2500
Sounds electrical, I hate electrical problems.
Old Oct 28, 2010 | 06:58 PM
Marx's Avatar
Marx
sounds like its going in to limp mode
