Last edit by: IB Advertising
Browse all: Lighting Guides
- Dodge Ram 2002-2008: How to Install HID Headlights
Step by step instructions for the do-it-yourself repairs
Got *HID* Problems? Check in here...
Caps wont fix that.
With non HID projectors but with bixenon bulbs.........
"low" beam should be on ALL the time. When you do high beam, all it does it energize an electromagnet in the base and "tilt" the bulb making it mimic high beam
The relay is sealed but can be disconnected from the harness. My suggestion is to go to ebay and buy another bixenon harness and try it
With that being said, high beam on bixenon bulbs usually sucks anyway because they light is so scattered. Might as well leave it as is IMO.
Caps wont fix that.
I'm betting it's missing the Hi-Low Connector and that's why the elecromagnet isn't being triggered...
I love the harness I got from the retrofit source... zero problems so far and been installed since a week after x-mas.
I have read and re-read alot of the posts on here. I purchased a kit off of ebay for my husbands 2006 Ram Big Horn. We know that he needs the relay and resistor. Right when we are convinced we are about to purchase the right kit, he becomes leary because from everything I read on here it seems he needs to relay harness for the 9007 and not the 9004. We purchased a Xenon kit...admittedly a cheaper one off of ebay. Can you guys confirm or point me in the right direction of what resistor and relays to purchase? Thank you.
Link to what I purchased...
http://www.ebay.com/itm/310874427296...84.m1439.l2649
His original bulb is Philips H13 12V 60/55W if that matters..
http://www.ebay.com/itm/190817924169
Now with you having separate lows and highs in those ebay headlights, you may have to modify the harness
Something in your wiring isn't correct. Keep trying. You're almost done
I've also seen Pins bend/break on the OEM headlight connector which can cause the low beams not to work b/c it turns the relay off.
It would also help us to know what year Ram you have, and what harness you are using.
