Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Jan 20, 2014 | 09:46 PM
  #651
weedahoe's Avatar
weedahoe
Hall of Fame Member
What you have linked isnt a "retrofit" IMO.
That would include projectors. I made a mistake and thought you were going to do projectors also.
I have a brand new set of headlights, Oracle LED halos, a full 35w HID kit and Morimoto projectors with shrouds and remote controlled color shifting Demon Eyes for available if you are interested. I would not do just HID bulbs in a headlight without projectors
Old Jan 20, 2014 | 09:55 PM
  #652
hfd419's Avatar
hfd419
Yeah I'm just looking for a easy solution which is why I was checking out the bulb kit. What's your headlights look like?
Old Jan 20, 2014 | 10:09 PM
  #653
weedahoe's Avatar
weedahoe
Hall of Fame Member
The headlights are I have are not assembled yet because someone might want to paint match the bowls first. Once they are put together it is not worth taking them apart and doing that. Best to do it one time
Old Jan 20, 2014 | 10:48 PM
  #654
hfd419's Avatar
hfd419
Eh it is a work truck for my company. I'm not looking for the flash just a performance bump. I do not have driving lights so maybe I add a set of factory driving lights to turn on with my low beams? I was hoping just the HID lamps in my stock headlights would give me the bump.
Old Jan 20, 2014 | 11:04 PM
  #655
weedahoe's Avatar
weedahoe
Hall of Fame Member
They will give you a bump but just be blinding to everything headed in your direction
Old Jan 23, 2014 | 04:29 PM
  #656
Izero's Avatar
Izero
So I just wanted to note that Morimoto has a recall on some of their Morimoto 3Five and 5Five DSP ballasts.... the issue becomes more prevalent when it is cold out.
The issue is that they aren't providing enough voltage and sometimes cause the bulb not to ignite as well as flickering.
Just wanted to post up that info incase anyone is having issues with Morimoto Ballasts.
Old Jan 23, 2014 | 06:36 PM
  #657
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thanks for the heads up
Old Jan 24, 2014 | 08:21 AM
  #658
Izero's Avatar
Izero
no problem
Old Feb 17, 2014 | 07:57 PM
  #659
chris Dc's Avatar
chris Dc
I am in need of some help, i bought a set of hids for my 06 dodge ram for the headlights and fog lights. Well bout a month ago the fog lights went out, after playing the the fog light plug to the relay box they came back, but now they have went out again. Now every time i hit the fog light button they dont come on and every light from the dash to headlights and dome lights flickers about 3 to 4 times. Whats going on??? There plug in by themselves would adding a relay fixed this? Please help
Old Feb 17, 2014 | 09:32 PM
  #660
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sounds like that is your issue right there. You have a loose or broken connection
