My Truck and the Transmission Mod
Old Nov 25, 2010 | 01:11 AM
  #31
BlueHemi's Avatar
BlueHemi
Originally Posted by The Cank
Ok I hope you all can see these, I took pictures of the engine bay. If you see the plug let me know where it is.
It's been a few years since I did this on mine but I'm pretty sure that is the TCM in this pic. The wire is in the bottom connector.
Old Nov 25, 2010 | 10:50 AM
  #32
sc13mw's Avatar
sc13mw
so if you cut the wire it will get rid of the torque management and the sonnax plug will up the pressure in the trans?
Old Nov 26, 2010 | 08:43 AM
  #33
The Cank's Avatar
The Cank
Pull the #7 wire (yellow with dark green stripe) on the 4th plug down. I will give this a shot.
Old Jan 12, 2011 | 03:08 PM
  #34
Chris1530's Avatar
Chris1530
can you do this on an 06.. eliminate the torque management ?
Old Jan 13, 2011 | 03:16 PM
  #35
Goat86's Avatar
Goat86
Hey guys, new to the forum. Can you eliminate the wire on a 02 for the torque management? What exactly will that do? I have seen the wire sonnax plug on airram.com is this the same one yall are using? Thanks
Old Jan 13, 2011 | 04:10 PM
  #36
HemiLonestar's Avatar
HemiLonestar
No, but you have the option of programming to modify your TM.
Old Jan 14, 2011 | 07:58 AM
  #37
weedahoe's Avatar
weedahoe
Hall of Fame Member
Correct per previous post above. TMR went to electronic controlled in 04+. For the 06 you can get a Superchips to manage shift points and controls and get a Sonnax trans line booster to help out. See my posts above about the Sonnax
It is the same one. We do have a How To and DIY in the FAQs though if you are electrically inclined
