Level & Tire
#21
#22
http://www.miata.net/garage/tirecalc.html
You can play around with that. If you're just looking for a wider tire you can keep the aspect ratio in check by lowering the second number to a 65 or a 60... but if your looking for a taller tire just check your clearances... The 285 will fit fine. My stock tire right now is a 275/60r20 which is exactly 33'' ... your 285s will be 32.7... I say check a 295!! (not sure if it will fit width wise or not.
#23
#24
#26
This is what you said.. SO READ!!! You Never explained yourself so that's what i did below
I stated here that the trucks never came with 33" stock
NO **** SHURLOCK!!! I never said you couldn't put 33s on it stock without a level
#27
Your post is adding nothing to the thread. If you have information that can help the OP then add a post, but if you are just trying to argue with facts then go to the open forums.
