3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
So after hours of searching ive found nothing on this topic im wanting to put a level on my 2007 1500 qc 2wd so i can fit bigger tires im currently running the stock 17" wheel and plan to keep it that way my question is if i put the 1.5" daystar level will i be able to fit 285/70-17 tires with no issues?
No..The biggest tire you could get stock from factory on 17" rims was 265/70/17.. Which is only a 31" tire. Whereas 285/70/17 are almost 33". On the factory 20" wheels they did come 33" tires stock
285/70/17 is about 32.5. You will have more than enough room for these with a level.. Level= anywhere around 33" if you want no rubbing at all and not stuffed.
3" body or 6" suspension= 35s
haha yeah im sure the girlfriend is barely 5' tall and i cant stand step bars so i have to keep it fairly tame plus getting a car seat in and out could be a chore down the road
what size level would be enough 1.5" or 2" id like it to look not so stuffed but id also like to keep the stock shocks or struts whatever you want to call them
You can reindex the torsion bars with new keys for 100 bucks or so and get 2". I got almost 3" but the ride was pretty harsh and backed it down to about 2.5.
I'm getting rid of my 285's and going with 315's later this month.
