2003 1500 rear end
Old Dec 5, 2010 | 11:29 PM
elliottdodge's Avatar
elliottdodge
Default 2003 1500 rear end
So I had a "clicking' noise in the rear end of my Ram, thought it was the brakes but nope, I ended up pulling the pumpkin cover and sure enough I found 1 broken clip in the bottom of the pumpkin, seal was leaking anyhow so I assumed something was wrong there. Now from what I have read there are PLENTY of people that have had this issue, can anyone tell me what they suggest using as replacement parts? I thought about taking my gears, etc. out and having the Dodge garage install the clips in the LSD. Or if I am that far is it easy enough to do? Also, if it is easy enough are they any gotchas?
I thought I read somewhere that a company makes a replacement LSD that does not either use this setup or at least is not susceptible to it...any replacements that you all know of?
Thanks much,
Elliott
Old Dec 5, 2010 | 11:49 PM
olyelr's Avatar
olyelr
I rebuilt the LSD in my 2nd gen with a buddy of mine. I had no prior with it, but we managed. It was quite a pain in the @ss though.
As far as an upgraded unit, there are plenty out there. Gear style limited slips are much more stout than the clutch style.
Old Dec 6, 2010 | 12:01 AM
That1guy's Avatar
That1guy
You can replace it with a detroit true trac, but if you pull the gears you have to reset the rearend. It has to be with in thousands of a inch.
Old Dec 6, 2010 | 12:23 AM
nh5's Avatar
nh5
http://moesperformance.com/index.php...oducts_id=9046
That's probably your best bet it works on 4WD trucks also. Replaces all the guts and no more inferior limited slip
Old Dec 6, 2010 | 01:41 AM
nussdawg395's Avatar
nussdawg395
There are tons of threads on here on this. All the info you can handle just search for auburn or detroit trutrac.
Old Dec 6, 2010 | 08:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, almost everyone that has had this issue has replaced the diff with something aftermarket
Old Dec 6, 2010 | 09:13 AM
elliottdodge
Well I hate spend 800 for the Detroit listed above but if that's what has to be done... I'll continue to shop around - many guys talk about the problem they have/had but not much on the solution. Thanks for the replies!
Old Dec 6, 2010 | 03:29 PM
That1guy's Avatar
That1guy
What he posted is the true trac and a set of gears and a master install kit. A true trac cost about 500 dollars. I suggest calling a good off road shop and talk to them.
Old Dec 6, 2010 | 04:25 PM
olyelr's Avatar
olyelr
The CHEAPEST solution to repair (not complete eliminate said issues from happening again) is to buy the rebuild kit... under $100.
The BEST solution is to completely replace the LSD... but cost is much greater.
Old Dec 6, 2010 | 05:15 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There is an Auburn LSD and new 456s gears right now on DT for sale for 250+shipping
