Whats wrong?
Old Dec 13, 2010 | 01:31 PM
huseman808's Avatar
huseman808
yes, i moved the doors while the vents were running by hand. I removed the linkage between the two doors, and did them individually and the temperature did change on both sides. it didnt feel loose or anything. I am 90% sure that there is nothing wrong with the blend doors.
Old Dec 13, 2010 | 01:38 PM
bigdaddyII's Avatar
bigdaddyII
So if you moved the doors by hand and the temp changed on both sides, but if you use the selecter and it only changes temp on the drivers side, sounds like you have your answer.
Old Dec 13, 2010 | 01:44 PM
huseman808's Avatar
huseman808
not quite. the passenger went from hot to cold and back. drivers side goes from lukewarm to coldand back.
Point is all the operation is there, just that the heat is not sufficient.
Its all so confusing
Old Dec 13, 2010 | 02:13 PM
dirtydog's Avatar
dirtydog
Moderate User
Well, forget about how much heat is there.
If you moved the doors by hand and you did get some heat on the driverside, then your blend door is the problem. As I stated before, the gear mechanisms strip out because they are only plastic. This means that the actuator will be rotating inside the stripped blend door and not moving it even though the blend door seems to rotate fine by hand and isn't bound up.
Now for the heat being not so hot.
Did you grab the hoses like I said to feel their temp? Or if you have a handheld IR heat sensor use that.
Old Dec 13, 2010 | 02:23 PM
huseman808's Avatar
huseman808
Dirty-
I did check the hoses and both of them are equally hot. Not so hot that I can't touch them, but they are hot. Also, the longer the truck is running thewarmer the driver side heat becomes(like say after an hour of running, its almost the same temp as passenger side). Which I don't think would happen if I had a door problem. I'm not trying to argue, I just want to make all of my information known, before I stick a bunch of time and money into something only to have it not be the problem.
Thanks.
Old Dec 13, 2010 | 03:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There are three doors there right? Not just two.
Old Dec 13, 2010 | 04:29 PM
huseman808's Avatar
huseman808
No, there is only 2 blend doors. Watch this video between 4:20-6:35. This is exactly what I dad, and how the parts reacted.
http://www.youtube.com/watch?v=KAclL84Qq8E
From the far left(drivers side)...
1st door controls air between floor and defrost. 1 motor
2nd door controls the panel vents mode.(on/off) 1 motor
3rd and 4th door are blend doors controlling temperature. 1 motor with a metal linkage between the two.(as noted in video)
5th door controls recirculation . 1 motor
Old Dec 13, 2010 | 05:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
These are two of my fav threads
http://www.dieseltruckresource.com/d...d-t210483.html
http://www.turbodieselregister.com/f...-pictures.html
Old Dec 13, 2010 | 06:06 PM
huseman808's Avatar
huseman808
thank you, ive been using them i found them in another thread you posted in.
Old Dec 14, 2010 | 08:36 AM
huseman808's Avatar
huseman808
anyone?
