Adding reardefrost..
Old Jan 12, 2011 | 04:07 PM
Geezir's Avatar
Geezir
Default Adding reardefrost..
So my truck does not have a defrost rear window. It looks like it was replaced at somepoint since the back door windows are tinted but the back window is not...so it may have had defrost at some point and they cheaped out on the window.
Anyways, I have heated mirrors so I have the defrost switch in the dash already. What I'm wondering is the worst case. Should all the wiring for the rear defrost be there already or would it be a matter of running all the wires and such as well (which would mean the time and money would be spent elsewhere).
Only reason I'm wanting to do this is my truck was bought to be a snowplow truck. Sometimes depending on the weather outside the back window will either fog/frost up or become covered in snow making work a pain in the ***.
Old Jan 12, 2011 | 04:28 PM
Bent's Avatar
Bent
Mine is a 04 SLT QC-SB 4x4, I have heated mirrors as well, but no Rear defrost.
In my fuse box, I have a relay and fuse for the heated mirrors, but no relay or fuse for rear window defrost.
My rear window was not tinted, but my two rear door windows were...
Old Jan 12, 2011 | 05:15 PM
HemiLonestar's Avatar
HemiLonestar
I looked into this, only thing that stopped was cost and finding a heated rear window to install. The pigtail may or may not be there (Mopars this vintage seem to have no consistency on this). If it is, then all you have to do is install window and plug in, it will turn on with heated mirror switch. If not, then you will have to get and install the harness to run it to the dash/fuse box. See here.
Old Jan 12, 2011 | 07:16 PM
Marx's Avatar
Marx
i have the defrost window but its not hooked up anyone have a wiring diagram?? or know how its hooked up? any pics?
Old Jan 12, 2011 | 08:02 PM
MikeHTally's Avatar
MikeHTally
Man, I suspect a rear-defrost window sounds a bit pricey! Hope it's worth the expense...
Old Jan 12, 2011 | 11:37 PM
Geezir's Avatar
Geezir
I know the owners of two salvage yards here in town so the cost of the window is essentially free.
That's why it comes down to whether or not the wiring harness is there or not. Looks like it's time to explore.
Old Jan 13, 2011 | 12:31 AM
Bent's Avatar
Bent
look in the PDC, there's a spot for the fuse and for the relay,
I'm not sure, but I'd suspect if the connections are there. the wiring should be in place too.
Old Jan 13, 2011 | 09:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have those Service Manuals with wiring diagrams in them in my sig link
