voltage indicator
Old Jan 21, 2011 | 10:16 AM
jetjarv's Avatar
jetjarv
Default voltage indicator
last winter my battery went dead in the evening. the only store available was walmart close so I bought a battery.
I've been noticing 2 things this winter.
1. it doesn't have very good cold cranking amps
2. the voltage indicator was always at the 12 o'clock position with the engine running, or so i thought. with the engine off it is slightly below 12 o'clock. now with the engine running it is 1/2 the way between the 12 o'clock and the first heavier black line.
I____I__x_I - engine running x is where the needle is
I__x_I___I - engine off
I___x___I - before the old battery went dead engine running.
I'm wondering if this cheapo battery is making my alternator work harder and will wear it out faster.
I've always used to purchase interstate battery replacement, but i haven't purchased a new battery in over 5 years. I don't know which one's are preferred.
thanks
Old Jan 21, 2011 | 12:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
when it is cold outside you ge a higher charge due to the battery temperature sensor under the battery. The PCM reads info from this and other sensors to adjust the charge (voltage regulator). Its normal when it is cold outside
Old Jan 21, 2011 | 12:25 PM
cheers007's Avatar
cheers007
Mine does the same thing too. I still have the same battery from when I bought the truck last year.
Old Jan 21, 2011 | 12:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Now you know why.......
Old Jan 21, 2011 | 01:35 PM
jetjarv's Avatar
jetjarv
Talking
THANKS! Appreciate your time to respond.
Old Jan 21, 2011 | 01:55 PM
Bent's Avatar
Bent
Wow - I had no idea there was a temperature sensor under my batter.
(I'm prolly goina to find out soon though, it's -34 C here this AM, and my battery is 7 years old.)
Old Jan 21, 2011 | 03:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ And its a $50 sensor also.
Old Jan 22, 2011 | 10:29 PM
lxman1's Avatar
lxman1
Site Moderator
Just a note, Walmart batteries are good batteries. Made by Exide I believe.
