Sparking Hot Wire
Old Jan 22, 2011 | 01:33 PM
bevoe's Avatar
bevoe
Default Sparking Hot Wire
Would grounding the hot alternator wire during insulation, damage the PCM and keep the engine from firing up?
2003 Ram 1500 3.7 Auto
Old Jan 22, 2011 | 02:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Do you mean "Installation" rather than insulation?
At any rate, sparking the alt wire is never a good thing, but your not necessarily dead in the water if this happens. I've sparked alt wires before without any recourse, but that's not to say bad things can't happen as it's always possible.
If your engine isn't firing, I would double check all of your connections and make sure you are getting proper spark and make sure your fuel system is pressurized and functioning properly.
Old Jan 22, 2011 | 09:59 PM
lxman1's Avatar
lxman1
Site Moderator
If your lucky, you blew a fuse. But yes, it could pop the pcm.
Old Jan 23, 2011 | 06:21 PM
bevoe's Avatar
bevoe
Thanks for the answers. I'll check a few more things out. But, I think I'm still going have to have it towed to the dealer to test everything on it.
