Tranny temp gauge install question.
Old Jan 25, 2011 | 09:36 PM
99ramman's Avatar
99ramman
Default Tranny temp gauge install question.
https://dodgeforum.com/forum/3rd-gen...gauge-diy.html
Is this all the same for my 08??? It should be. I found the pillar......not easy for an 08. I just wanted to check before i order addapters I don't need.
Old Jan 26, 2011 | 07:26 AM
NHHEMI's Avatar
NHHEMI
Parts list should be accurate as far the the two adapters. You can also use Auto Meter's temp sender manifold #2286 that goes into the tranny line which eliminates adapters and crawing under the truck for test port #3. That is what I am going to do. Easier on me cutting into the line near the cooler/radiator than crawling under the truck to get to TP3.
What gauge are you planning on using? Did you know Auto Meter offers a factory matched gauge for the Rams? They offer it in short sweep( #8549 )and full sweep ( #8557 )in the required 2 1/16" size. I decided to go with this gauge in the short sweep style.
Why did you have a problem finding the SRT-10 A-Pillar? Any Dodge dealer can order the SRT-10 pillar for 06-08( 09 HD's too )Rams. Standard OE part. I got mine from the dealer I use for $40. Took 2 days to get in. ( Mopar # ZL39BD1AA )
I haven't actually hooked everything up yet as the weather is too bad. Just have it all here( gauge hasn't arrived yet )waiting.
Old Feb 1, 2011 | 11:51 PM
RamMN's Avatar
RamMN
this is great info....what is the difference between short sweep and long sweep? does it really make a difference? Anyone find a good place to get a deal on the parts?
Old Feb 2, 2011 | 07:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you get the Diablo Trinity you would not need to add a gauge......LOL
Old Feb 2, 2011 | 12:54 PM
NHHEMI's Avatar
NHHEMI
Short sweep has less of a temperature range and fewer points of data. Full sweep as the name implies has a greater temperature range and more points of data.
Here are the Dodge OE match gauges in SS and FS so you see whhat I mean...
SHORT SWEEP:
FULL SWEEP:
Old Feb 2, 2011 | 02:44 PM
SilverBullet08's Avatar
SilverBullet08
my set up is for sale if you want it...
Old Feb 2, 2011 | 09:31 PM
RamMN's Avatar
RamMN
i am interested silver bullet I'll send you a pm. I've done business on here before and can give a reference.
Old Feb 4, 2011 | 08:43 PM
rbrumm's Avatar
rbrumm
I have the Phantom II...wish I would have known about the 8557..or is it new. Put mine in about a year and a half ago...the manifold works really well.
Old Feb 19, 2011 | 04:05 PM
99ramman's Avatar
99ramman
well went to install my stuff today as it's a BALMY 32'! I apparently do not have a test port 3.......I have the spots for them they are just not there. Looks like I'm on hold til I get my manifold kit.
Old Feb 19, 2011 | 06:22 PM
GHALL219's Avatar
GHALL219
Thanks for all the info I got a gauge from a friend and I still haven't open it yet just getting all the info together.I like plaining stuff like this out
