Cannot figure this out!! (start issue)
Old Mar 4, 2011 | 11:58 PM
popdog's Avatar
popdog
Originally Posted by weedahoe
I know this isnt the same but years ago i had an Olds 350 and it has a distributor cap and button setup. Timing was adjusted by turning the distributor CW or CCW. With it advanced the engine ran better. But get it too far and (like you) after the engine got hot and was shut down, when you tried to start it back up while it was still hot you would have to turn back the timing.
Are you suggesting my truck is too advanced for his own good? I always knew he was brilliant!
Old Mar 5, 2011 | 12:37 AM
Feve74's Avatar
Feve74
That's pretty funny!! If the truck attempts to start, it suggests to me that it is fuel related, not electrical. That being said, some electrical parts affect fuel. I'm not too familiar with these engines, but an idle air control valve that doesn't work properly would cause this. Some vehicles use an idle air temperature sensor to send a reading to the computer also, which in turn rotates the throttle plates until you get the appropriate TPS reading.
Nutshell = Somewhere in between IAC/IAT telling the PCM to rotate the throttle plates and the verification the PCM receives from the TPS
I would also recommend getting decent electronic replacement parts. O'Reilly stocks Borg Warner, which in my opinion are much better than an Auto Zone quality part. Not plugging anyone, just personal experience. Some of the sensors are cheap enough that it doesn't hurt to replace them anyway, as long as they are as good or better than the original.
Good Luck!!
Old Mar 5, 2011 | 10:25 AM
dirtydog's Avatar
dirtydog
Moderate User
IAT temp sensor could be faulty in the open loop mode or too high of resistance.
You should be able to use a multimeter and measure the resistance across the terminals of the sensor. You don't even have to remove it just unplug the pigtail.
You should be upwards of 60k-ohms when cold and 3k when hot.
You touching the gas pedal doesn't give it more fuel per say, but it provides the needed cfm flow through the throttle body because "cold engine's" start rich which is the issue. With little oxygen and lots of fuel for a hot vehicle, you will get a flooded no-start condition until you provide more airflow.
Old Mar 7, 2011 | 05:05 PM
popdog's Avatar
popdog
i agree with dirty, i dont think it's fuel related, I believe it's a lack of oxygen. My only worry is that, if the IAT is faulty, how do I go about replacing it? I haven't looked at the way it's setup quite yet but i'm under the impression it's built right into the throttle body =/
Old Mar 7, 2011 | 05:22 PM
drewactual's Avatar
drewactual
fwiw- I got a really dang good deal on some new injectors.. they are a full pound more flow than the stock.. I altered my tune, to address it, but only mathematically, and not by using a wide band a/f on it.. I know I'm running rich still, but I don't know how rich yet until I install the gauge (that's been in my tool box for a month).. reason I say this: I have issues with starting just like your issues..
since you haven't replaced injectors- the next place I'd look is o2 sensors- which doesn't really make sense because they don't start altering your fuel flow until you go to closed loop.. but they could be- long shot..
more likely, you got a sticky injector that isn't closing the gates as it should... you could grab a stethoscope and listen to them while idling, and see if one is out of rhythm from the others..
I know my issues have to do with running rich- and it sounds like yours may too- but not for the same reasons.. do you have any way to look at your a/f on start-up?
Old Mar 7, 2011 | 05:26 PM
popdog's Avatar
popdog
i've got a superchips 3865, havent used the diagnostics in a while but i *think* it does give you an a/f reading..
Old Mar 7, 2011 | 07:25 PM
chefred112's Avatar
chefred112
iat sensor is probably the easiest to change...it's located in the hemi hat on 3rd Gen's. Just unplug, twist and pull it out..
Old Mar 7, 2011 | 11:49 PM
popdog's Avatar
popdog
Orly? Nice. I'll have to look into it hopefully i get a warm day this week.
Old Mar 8, 2011 | 02:04 AM
chefred112's Avatar
chefred112
the whole process from poppin the hood, unlock connector, press tab, pull to release, twist sensor counterclockwise, pull out, insert new sensor, twist to lock into place, re-attach connector, slide locking tab, close hood... about a minute..
Old Mar 8, 2011 | 02:05 AM
chefred112's Avatar
chefred112
..and the sensor should be under $10 from the dealer (yea, that shocked me..lol)
