Throttle body cleaning Question
Old Mar 13, 2011 | 08:35 AM
breadguy5's Avatar
breadguy5
Default Throttle body cleaning Question
This is my first post on here so bare with me . Going to be tackling my first TB cleaning ,i own a 02 ram 4.7 ,i have read on here all about how to do it ,just havent seen anything about if i should be removing the two sensors that are attached the TB . My worry is if i dont i might damage them . Should i remove them or not ,any help will be appreciated.
Old Mar 13, 2011 | 01:21 PM
Tdot_RAM's Avatar
Tdot_RAM
EDITED...As informed by TSB.....
Old Mar 13, 2011 | 06:12 PM
MikeHTally's Avatar
MikeHTally
DO NOT use throttle body cleaner or carb cleaner. Dodge issued a TSB saying to use non-chlorinated brake cleaner only.
Old Mar 13, 2011 | 07:43 PM
Kscha41's Avatar
Kscha41
Well I used TB cleaner without any problems. The very next day after cleaning it, I read on here not to use TB cleaner. It got me a little worried but nothing bad has happened yet.
Old Mar 13, 2011 | 08:07 PM
breadguy5's Avatar
breadguy5
So i take it that i should take out the sensors because Brake cleaner is what i should be using to clean it with ??
Old Mar 14, 2011 | 09:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If yuo have already cleaned it then dont worry about it. They say not to use carb cleaner because some guys go crazy and dip the entire unit in solution or go spray crazy and get it everywhere including in the electronics. Just use the non-chlorinated brake cleaner and be careful where you spray it.
Old Mar 14, 2011 | 05:09 PM
Ben D.'s Avatar
Ben D.
on this same topic is there anything special to keep aware of when you have one of the electronically controlled throttle trucks where there isn't a cable going from pedal to TB..
Also do you guys replace the TB gasket after removing it or just use some form of RTV?
Old Mar 14, 2011 | 05:14 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The TB gasket is a bead type gasket that fits on the intake itself and should not come out or off.
As for the chems to use, just keep it out of any electronics.
