leveling a 2005 4.7
Old Mar 15, 2011 | 06:22 PM
buzzmkduce's Avatar
buzzmkduce
Default leveling a 2005 4.7
I would like to level my 2005 4.7L. I have heard some pros and cons but wanted to talk to some people who would really know. It needs to go up about 2" and im looking to find out the best way to achieve this.
Thank You,
Old Mar 15, 2011 | 07:43 PM
JDG103's Avatar
JDG103
first things first what kind of leveling kit are you looking for and what kind of rig do you have is it a 4x2 or a 4x4, and what size tires are you wanting to run on it
Old Mar 16, 2011 | 02:36 AM
xsparta11x's Avatar
xsparta11x
That is a good first question. 4x4 or 4x2. If its a 4x2, you have a couple options... the first question you want to ask yourself though is how do you want to do it. You can purchase Extended coil springs, Coil Springs Spacers, I've seen some chit heads do just shocks and fail miserably,or a combination. I personally recommend the coil spacers and new shocks method. Fat bob's Garage.com runs a bundle for I believe 04's and up Leveling kits. its about 150 bones which is not to bad. It is rated at 2.5". What is really cool is that they give you Coil springs spacers and New shocks that are 2" longer then stock to compensate. You can also upgrade the shocks to that are nitrogen filled in the package for only like $12 extra. Anyways... I did a review on it a couple months back
https://dodgeforum.com/forum/3rd-gen...it-review.html
Over all I was extremely pleased. Did not loose any ride quality and now my truck sits perfectly level. No matter which way you go as far as brand and everything goes, just make sure that if you go anything larger then 1.5" of lift in the front, replace the front shocks. They will bottom out every time you hit a bump if you don't. Also, GET AN ALIGNMENT DONE RIGHT AFTER YOU INSTALL THE KIT!!!!Wither it be a 4x4 or 4x2, this is the most important part of the entire install. Other then that, Enjoy the truck!
Old Mar 16, 2011 | 05:05 AM
Matt99's Avatar
Matt99
the drivetrain (2wd or 4x4) makes the biggest difference but if you dont mind a slight reduction in ride (bumpiness and handling) you can do spacers for about$100 plus install/alignment
Old Mar 16, 2011 | 05:41 PM
buzzmkduce's Avatar
buzzmkduce
Sorry guys its a 4X4 quad cab. Im not sure how I would level it due to the fact that im not sure how many different ways there are. I have had 33's on the truck before and would like to go back to them but just level it out for looks.
Old Mar 16, 2011 | 05:44 PM
Matt99's Avatar
Matt99
you can crank your torsion bars. I think hammer has a DIY on it
Old Mar 16, 2011 | 08:01 PM
buzzmkduce's Avatar
buzzmkduce
I think they are pretty much cranked all the way. But ill check the DIY thanks.
Old Mar 17, 2011 | 10:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
if they are cranked all the way you would 1) have CV axle angle issues more than likely and 2) you would already be levered or more in the front
