4" lift on my truck
no. lol.
You need spindles to lift up the front. Look at them and you will see where they go. they will get you pretty close to level on their own, you might need a .5in block or so in the back to make it right. But the Ubolts hold the block on the leaf springs and axle.
The shocks do not need to be replaced and wont provide lift on a 2wd
no. lol.
ohh i didnt know you had 2" already. Okay lets see. How far away from level are you at this point? Im guessing about .75"? so you would need a 3" block to make up for the spindle, and then take away .75" to level from the spacer. So all in all, I think a 2" block (or get the lift shackles) would do what you want.
and with 2" blocks you dont need new shocks. the rear of your truck is designed to have more travel than the front and 2" is about the max you can go on lift without buying new ones. Stock 2500 4x4s (I dunno about 2wd) have a block in the back stock and their shocks would fit perfect if you happen to have one in a pick and pull around you
When I did my 6" Rough Country lift it came with 3" spindles and longer springs in the front and 3" blocks in the rear. That leveled me out pretty much.
Then I added 2.5" Daystar coil spacers in the front to lift my front end higher. I also added 3" shackles in the rear to lift it 3"
I hope this helps.
I hope this helps.
