THIS is how you get better brakes!!
Old Apr 1, 2011 | 10:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree on the cautiousness. The hydroboost is power fed from the PS pump so that is something to be mindful of.
On a side note, I was thinking earlier and Im sure now that the reason my lines were short earlier was because of my 3" body lift.
Old Apr 1, 2011 | 10:56 AM
areinike's Avatar
areinike
Originally Posted by Mike Jazz
Might as well chime in on this since nobody else is.
lol it was only like 12 minutes!
Old Jan 6, 2013 | 05:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As an update
Lots of pics HERE
Old Apr 21, 2013 | 03:00 AM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
In your parts list at the end of the OP, you mentioned 2 qts of ATF4...do you use that in place of power steering fluid? Cuz you don't mention where the ATF goes, and I understand that with more tubing for he hydroboost, that it will need more PS fluid.
Old Apr 21, 2013 | 04:35 AM
rought's Avatar
rought
any effect on the anti lock brakes or do they still work normal?
Old Apr 21, 2013 | 09:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Anti lock brakes work fine. When you disconnect the power steering pump lines from the rack you will lose fluid. The new ATF is to replace that. DOT 3 or 4 does go in the master cylinder
Old Apr 27, 2013 | 10:32 AM
UTOT's Avatar
UTOT
Did you have to change out the OEM calipers or are the OEM calipers ok with the pressure built with the upgraded Hydro-Boost?
Old Apr 27, 2013 | 03:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
OEM calipers are fine. I still run this setup today with now 90K+ miles
