Ram cutting out at low acceleration between 45-65mph...
Old Jul 18, 2012 | 04:45 PM
  #21
DodgeBluto's Avatar
DodgeBluto
I would consider the tranny solenoids or tq converter slipping. Niether will light up the engine light but if scanned will throw a code p0740
That really sounded like the OP issue. But as for your new issue, I woudl assume a tranny shop would have scanned it so that is going to rule that out
Old Jul 19, 2012 | 10:53 PM
  #22
detailedEye's Avatar
detailedEye
Yeah, they did a scan when driving it and didn't find any codes being thrown. They indicated the tranny is working correctly and it's a good shop so I believe them. Glad it's been ruled out, but sure wish I knew what it was.
Would a bad injector cause this? From the shops write-up during driving and monitoring the ECU data, "found no data very far out of range, fuel trims bouncing somewhat." It's odd it's only in a certain RPM or speed range. It seems to be the worst around 65 mph, which is about 1800 RPM. Speed up to 70-75 and it smooths out.
I found in the service manual how to test an injector and I'll probably go through and do that (fun), is there a way to test if a coil is bad?
Truck has 64k miles on it.
Thanks!
Old Jul 20, 2012 | 09:47 AM
  #23
DodgeBluto's Avatar
DodgeBluto
You would think a bad injector would throw a 300 misfire code.
Old Feb 5, 2025 | 12:56 PM
  #24
apjcustoms's Avatar
apjcustoms
im having same exact issue 03 4.7 no egr valve trans rebuilt as well does anyone have the answer to the cause ?
Old Feb 5, 2025 | 04:54 PM
  #25
Alex Medeiros's Avatar
Alex Medeiros
It's almost a 13 year old thread, so you're better off making a new one.
Old Feb 5, 2025 | 05:05 PM
  #26
He has one.
Old Feb 5, 2025 | 06:28 PM
  #27
apjcustoms's Avatar
apjcustoms
I had one but just because I have a thread doesn't mean I just sit around and wait for other people to answer it. This one particular issue plagues a lot of Dodge owners with the gen 3 specifically the 4.7 and I've yet to find a finite resolution and I was hoping the fact that multiple people jumped on this thread with a similar issue. Just one of them would maybe shed light on what they did to resolve it so I could continue in trying to suss out my issue
Old Feb 5, 2025 | 07:32 PM
  #28
Of the original posters in here, I think only lxman are still around.....
