Spark plug ??
Old Apr 9, 2011 | 09:25 PM
Lowrider82's Avatar
Lowrider82
Default Spark plug ??
2008, 1500 SLT 4.7, 2WD What are the OEM plugs? I bought some Bosh copper super +, part # 7962 which were cheap. Not fond of bosh but all they had, are they good, cause I have had problems in the past with Bosh in another vehicle I owned. Also the coil packs, how long do they last on average? Not going to replace them as they are coil packs not boots.
Also plan on doing the rear differential while I'm at it, is there a rear gasket or will RTV sealant be all I need? Also if RTV sealant is all I need what part #? I was thinking the black or grey.... Also how do I know if I have trac-loc so I know if I need the friction modifier?
Old Apr 9, 2011 | 09:32 PM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Some use the gasket, some just use RTV...I use both. Just go to Advanceauto.com enter your vehicle info, etc. It'll give you the part #, they're only about $5.
Not sure on your year truck for plugs, check the 3rd Gen FAQ Spark Plug thread.
To determine if you have limited slip, jack rear so wheels turn freely, turn one of the rear wheels. It the other wheel travels in the same direction, you have an LS diff, opposite direction, you have an open rear end.
Old Apr 9, 2011 | 11:03 PM
Lowrider82's Avatar
Lowrider82
thanks. just checked the FAQ's page, didn't know it was so indepth.
Old Apr 10, 2011 | 12:28 AM
lxman1's Avatar
lxman1
Site Moderator
I would use the black RTV on the rearend.
Take the plugs back if you can and try to find some Champion copper plugs or NGK V-Power copper plugs for the top. The bottom 8 plugs are good for 100K miles.
Old Apr 10, 2011 | 01:34 AM
Lowrider82's Avatar
Lowrider82
thats the plan after reading the spark plug thread. i will get oem plugs from Napa or where ever. these i don't think are preium as i payed only about a 1.50 maybe closer to 2$ but still
Old Apr 10, 2011 | 10:00 AM
Lowrider82's Avatar
Lowrider82
Is it Necessary to use electrode grease on the top plugs since it's the one with the coils
Old Apr 10, 2011 | 12:20 PM
lxman1's Avatar
lxman1
Site Moderator
I would use the dielectric grease on the coil boots, yes. This helps seal out moisture and will make them come off the plugs easier the next time you change the plugs.
Old Apr 10, 2011 | 01:37 PM
Lowrider82's Avatar
Lowrider82
Seems I have another problem. The socket fits tightly in the hole where the spark plug is. It is 5/8 right?
Old Apr 10, 2011 | 01:59 PM
Lowrider82's Avatar
Lowrider82
Never mind I found a smaller socket in 5/8. I'm rolling now
