Transmission Diagnosis 48RE
Old Apr 10, 2011 | 12:10 PM
shepco's Avatar
shepco
Default Transmission Diagnosis 48RE
My stock 145,000 mile 06 Cummins seems to shift from 1st to 3rd at 2,500 RPM or so. 2nd feels like neutral when I can get it in there by manually down shifting. It kinda will go into 4th when it is cool, but RPM is a little high for 4th and it will change a couple hundred (speed constant) depending upon the grade being pulled. This is a "one Sunday morning" sudden onset problem; fluid looks good and smells like rosemary lamb with mint jelly. I have not pulled that much and have been generally easy on it; but would like some upgrades. Could this be a repair or do I order a rebuild kit? Any and all opinions will be greatly appreciated.
Old Apr 10, 2011 | 12:19 PM
lxman1's Avatar
lxman1
Site Moderator
Are you getting any codes? Could be bad/sticking solenoids in the valvebody.
Old Apr 11, 2011 | 06:18 PM
shepco's Avatar
shepco
No codes. Sounds like it is a front band. Question now is: Do I get a Suncoast or Goerend or is it better to save the shipping cost from those guys and spend it on having one built locally in Phoenix AZ?
Old Apr 11, 2011 | 07:08 PM
lxman1's Avatar
lxman1
Site Moderator
If there is a good reputable shop in town, I would go that route. That way if there is a problem, you won't be wasting time shipping it back and forth.
Old Apr 12, 2011 | 12:09 PM
shepco's Avatar
shepco
Thanks Ixman, plenty of tranny shops around here, I am going local.
Old Apr 12, 2011 | 02:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Please let us know what you find out
Old Apr 14, 2011 | 01:51 PM
shepco's Avatar
shepco
After much confusion about what kind of build I needed and deciding who to do it, I ended up at Quality Transmission on McClintock and Rio Salado in Tempe. There are many opinions about TC's, billet, etc. The whole trick is finding someone honest who really knows the practicle side of building a tranny. One shop recomended in a forum that I checked out seemed good, but what they said I was getting in the build for the price turned out to be to good to be true; based on what I learned from several other shops and comparing to online guys like Suncoast and HTT etc. Another shop had me into a 5 or 6 thousand dollar build without any of the good stuff I was getting from Quality Transmission for much less; Needless to say: It is especially easy to get taken advantage of in this area of the auto industry. For honest shops, it was a toss up between Quality and Trail Transmission in Apache Junction for my $3,500 rebuild that I am sure will be good for my needs (occasionally towing a boat with camper on the truck). End of story; go to Quality or Trail.
Thanks for helping.
Old Apr 14, 2011 | 08:05 PM
lxman1's Avatar
lxman1
Site Moderator
Good job on shopping around. Sounds like found the right place to go.
