Trans issue
Old Apr 13, 2011 | 11:14 PM
crusher73's Avatar
crusher73
Default Trans issue
Need help my 05 ram 5.7 auto trans 4x4 takes too long to shift and when shifting has high rpms up 3000 Just seems to take too long to shift. found some info on autozone about possible trans cooler return filter.
Old Apr 14, 2011 | 07:36 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Apr 14, 2011 | 09:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. So what exactly is your question? How many miles are on the trans and when was the last time you changes all the fluid and filters? With an 05 an at average of 60k it should have been done twice already. Once at 30k and another at 60k
Old Apr 14, 2011 | 11:40 AM
Rich 2500's Avatar
Rich 2500
Is that the only symtom? How long has it been that way? Does it change hot or cold? Did you check for codes?
Welcome to DF.
Old Apr 14, 2011 | 10:03 PM
crusher73's Avatar
crusher73
MY question would be what would i look for that would cuase this, I am probably bad for not having the trans fluid changed yet. It seems to have not a whole lot of power and seems to take forever to shift gears running high rpms up to 3500.
Old Apr 14, 2011 | 10:08 PM
crusher73's Avatar
crusher73
this is the only symptom, it has been like this for about a month and a half. It runs like this all the time hot or cold. i have no idioit lights on. Can you still check codes with no lights.
Old Apr 15, 2011 | 08:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can still check for codes and there may be some store or maybe not.
You could have something as simple as a leak in the o-ring on the flat filter and losing pressure until a certain amount builds. Go buy you several quarts of AFT4, the correct filters for a 4wd 545rfe trans, some Permatex gasket maker and get out there and change the fluid and filters and see if it helps. You will also need a mechanics pick set (about $10) to get the old o-ring out of the valve body. Do not put the new o-ring on the neck of the flat filter and put it in place. Take something and gently tap the o-ring back up in the valve body first.
Old Apr 15, 2011 | 08:16 AM
Rich 2500's Avatar
Rich 2500
Well, if it was mine I would reset the PCM just for sh!tz and giggles, and if that didn't have any effect I be off to the dealer and have them check it out with the star scan, or what ever they are calling it. I would be suspect of the shift soleniod.
Old Apr 20, 2011 | 09:09 PM
crusher73's Avatar
crusher73
Thanks for all the input, sorry have not responded in a few work late. I have tried to reset the computer still same results, now seems to be getting worse off to the dealership tomorow
Old Apr 21, 2011 | 07:58 PM
Rich 2500's Avatar
Rich 2500
Be sure to keep us posted, good luck.
