Vibration on the highway
Old Apr 20, 2011 | 07:40 AM
X2K's Avatar
X2K
Default Vibration on the highway
Ive been getting a vibration on the highway around 60mph that feels like its coming from the rear. I only picked up this truck about a month ago and its still under warranty so I brought it back on Monday to have them check it out. I left it there and they called me and said that they think there is a bad tire so they were gonna rotate them and try to figure out which one was bad. That was unsucessfull because after they rotated them there was still a vibration at the rear. They told me that they think it might have a bad shock so they were going to replace the rear shocks and that they would have them in today(Wednesday). Im no mechanic but to me I dont see a slight vibration coming from a shock. What else could it be?
At least they left me with decent loaner, I told them keep it till its fixed.
Old Apr 20, 2011 | 09:05 AM
lxman1's Avatar
lxman1
Site Moderator
If it has the OEM Goodyear tires, it could have more than one bad one. There have been many complaints about them breaking belts and such. I guess I have been lucky since mine have been good so far.
They might try balancing all 4 tires and if that doesn't work, check the u-joints in the driveshaft and pull the rearend cover and look for shrapnel in there from failing LS clutch clips.
The oem shocks are weak. I replaced mine with Bilsteins as soon as my 3yr/36k bumper to bumper warranty ran out
How many miles are on the truck?
Old Apr 20, 2011 | 10:10 AM
Rich 2500's Avatar
Rich 2500
Take a good look at the driveshaft, especially if you have an aluminium shaft.
Old Apr 20, 2011 | 10:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, a bad tire or one slightly out of balance and a bad or weak shock would certainly pick up the tire issues and amplify it. But also a warped rim or bent axle as well.
Old Apr 20, 2011 | 01:26 PM
X2K's Avatar
X2K
The truck has 35k on it. I was more leaning to the axle or driveshaft problems as well. The shocks if they want to replacem them as well is fine by me.
Old Apr 20, 2011 | 06:19 PM
X2K's Avatar
X2K
They called me again this evening for an update. They replaced the shocks and it still has a vibration (surprise). They asked me again if I mind keeping the truck there so they can replace the U-joints too. I figure they can keep replacing parts at their cost and not mine. By the time they are done I will have a rebuilt truck. They always make sure to ask me if I am still ok driving this loaner. You think if I wasnt they would get me another? Kidding..
Old Apr 20, 2011 | 08:28 PM
lxman1's Avatar
lxman1
Site Moderator
What kinda loaner do you have?
Old Apr 20, 2011 | 09:06 PM
X2K's Avatar
X2K
09 Cherokee Overland. I'm kinda getting spoiled with all the options. I never knew a vehicle could have so much.
Old Apr 20, 2011 | 09:18 PM
X2K's Avatar
X2K
What should I be looking for?
Old Apr 20, 2011 | 10:58 PM
lxman1's Avatar
lxman1
Site Moderator
Warpage and/or twisting. Also make sure there isn't a spot where a weight used to be.
Nice loaner!!
